Hi all,
I'm new to the IGNITION application.
I am currently working on the PERSPECTIVE MODULE and need assistance with the TREE aspect.
Here is the Scenario:
I need a + button at the end of the TREE's Parent folder that will attach a CHILD folder underneath it when clicked.
[Screenshot Below]
Can we alter the Tree to conduct these types of tasks, or are there other options?
Thanks in Advance,
I wouldn't think it's possible easily.
What I've done was add a small flex container above the tree with a handy filter and a + button and only enable the button if a valid selection is made on the tree. Operation is easily understood by the users.
What I've done was add a small flex container above the tree with a handy filter, tree expand and collapse buttons and a + button to add branches. In my case the button opens a popup to define the properties of the new entry. Another option you could consider for your application is to only enable the button if a valid selection is made on the tree and then insert below that level. You just need to consider how to add to the root of the tree.
