Alternate clicking
what can i do when i click the highlighted one then the remoe:true in instance 0 turn into false . like this
and when i click the other it become like this
You can send a message on the base view and implement the message handler on the flex repeater to set the value remove as true.
Method 1:
On base view:
system.perspective.sendMessage("lotCarrierSelection", payload = {"carrierName": "one"}
On message Handler: check and set the prop like this
if payload['carrierName'] == 'one':
    instanceProps['remove'] = True
Method 2:
Configure the 'remove' parameter in the base view as 'Output'
By clicking on the :arrow_left: icon beside the param name (Params section of view )
not working
The methods suggested by vasanth.p does work as a concept. However, you won't be able to just copy-paste his example code. You would need to modify it to your specific case.
i try the suggestion and modify depending to what i need. but does not work
You'll need to be more specific. You can't expect people to put in effort to help you if you don't even provide the errors you run into.
