This is actually unrelated to that other issue. I’m guessing you are using IE8 or aren’t on Windows or are using some other browser. Our java detection javascript leaves something to be desired. Note that this message says that if you hit “cancel” it’ll try to launch anyways.
Feel free to turn off javascript detection in the config/system/settings area.
I have the certificate problem with two computers. (Both have update 14)
One computer has IE and an acceptable version of java and the other uses a different browser and shows an unacceptable version of java.
The orignal problem was “Unable to launch” and the details showed a certificate problem. I made the mistake of linking the java version issues together.
I still cannot launch a project though. I went so far as removing the reporting plugin and restarting the gateway.
I really don’t think that it should be necessary to unistall 6u14. I know lots of people who are using 6u14 sucessfully. Are you using any other plugins? Like maybe the ActiveX plugin?
Yeah, all plugins need to be upgraded for 6u14. If you’re not using it go ahead and remove it. Otherwise re-download it from our plugins page - the new version shouldn’t cause the certificate problem.
