Please, I need help with scripting. My objective is to change manually a boolean variable, then when this variable changes, another tag has to assume a fixed value, 40 if the boolean is set to true, false when it is set to 0. What I have to do ? I have tryed this
if “verofalso” == 1:
system.tag.write(‘verofalso1’,40)
else: system.tag.write(‘verofalso1’,0)
Hi! Welcome to the forums!
If this is a tag change script, you also need to specify the tag provider, even if it is the default one:
if "verofalso" == 1:
system.tag.write('[default]verofalso1',40)
else:
system.tag.write('[default]verofalso1',0)
A side note: if you wrap your code within the Code Tags using the button above the editor, it makes your code easier to read…
[attachment=0]2016-08-08_16-40-54.png[/attachment]
So if I understand this correctly, what you want to do would look something like this:
value = system.tag.read('[default]verofalso').value
if value == 1:
system.tag.write('[default]verofalso1', 40)
else:
system.tag.write('[default]verofalso1', 0)
