I'm building a perspective app to viewed with the mobile ios app. I've disabled pull down to refresh but is there a way to anchor the view so it doesn't move up and down when you drag your finger? I need it to be fixed solid.
Hey @aharris ,To keep components and objects stationary in the view, we typically use the Coordinate Container. However, if the view is larger than the screen size the scrolling will be enabled for the user to access the rest of the view.
Which container are you using? Are there any other objects on the screen that may be forcing the screen to scroll?
If there are more components/containers at play, I would suggest opening up a Support ticket with us at inductiveautomation.com/support
