I have this template that has a couple of rows of components, anchored horizontally that stretch to fill the width of the template.
When I use the template editor sizing handles to make it narrow, the template itself looks fine, but the instances don't look the same - even after reverting to the master size.
initial width 440:
new width 417:
I don't understand why it behaves this way, even at the master template size when the master template looks fine.
And then changing it at the window level, instead of the master template level, it looks as I would expect, but I actually want to change the template size so that I don't have to resize it every time
