So this is somewhat strange as I have these fan graphics with a rotating blade assembly. However, I’m seeing the blades starting to “spin” off the shape and around the screen for only a few of the fans on my screens. Alignment doesn’t seem to be an issue as I have another ten or so fans with absolutely no problems. Any ideas?
What version are you running? I had that same problem and it was fixed in 7.3.2 I believe. I had gears that rotated and the would fly to the left and get really small. Only in the client though, the designer was fine.
