Animation of Symbol Factory, rotation out of axe
I'am tryng to rotate Wind turbine I get this component on symbol Factory but the rotation is out of axis
this what I using on stylesheet
@keyframes rotateTurbineWind {
 0%{
100%{
    transform: rotate(360deg);
    transform-origin: 50% 50%
}  transform: rotate(0deg);
I try set origin to 0degr, but it isn't work.
I would recommend, just creating your own SVG, so then you know exactly where the center point is.
Likely what is happening here, is float rounding error, which is common in my experience among the Symbol factory.
If you need assistance with that, I can likely whip something up.
This looks centered, but it still looks wonky due to the angle it's drawn in.
View pasted as JSON.
  "custom": {},
  "params": {},
  "props": {},
  "root": {
    "children": [
        "meta": {
          "name": "Wind turbine - offshore - perspective view 2"
        "position": {
          "height": 615,
          "width": 561,
          "x": 110,
          "y": 123
        "props": {
          "elements": [
              "name": "symbol",
              "type": "symbol"
              "elements": [
                  "elements": [
                      "name": "stop",
                      "offset": "0",
                      "stopColor": "#999999",
                      "style": {
                      "type": "stop"
                      "name": "stop",
                      "offset": "0.5",
                      "stopColor": "#E5E5E5",
                      "style": {
                      "type": "stop"
                      "name": "stop",
                      "offset": "1",
                      "style": {
                      "type": "stop"
                  "gradientUnits": "userSpaceOnUse",
                  "id": "SVGID_1_",
                  "name": "SVGID_1_",
                  "type": "linearGradient",
                  "x1": "23.5085",
                  "x2": "27.6169",
                  "y1": "72.6316",
                  "y2": "72.6316"
                  "d": "M27.617,99.506l-0.913-53.747h-2.282l-0.913,53.747H27.617z",
                  "fill": {
                    "url": "url(#SVGID_1_)"
                  "name": "path",
                  "type": "path"
              "id": "Group_Pole",
              "name": "Group_Pole",
              "type": "group"
              "elements": [
                  "d": "M28.358,99.583v14.492",
                  "fill": {
                    "paint": "transparent"
                  "name": "path",
                  "stroke": {
                    "paint": "#B00C0A",
                    "width": "0.25"
                  "type": "path"
                  "d": "M27.788,100.495h0.57",
                  "fill": {
                  "name": "path",
                  "stroke": {
                    "paint": "#B00C0A",
                    "width": "0.25"
                  "type": "path"
                  "d": "M27.788,101.978h0.57",
                  "fill": {
                  "name": "path",
                  "stroke": {
                    "paint": "#B00C0A",
                    "width": "0.25"
                  "type": "path"
                  "d": "M27.788,103.348h0.57",
                  "fill": {
                  "name": "path",
                  "stroke": {
                    "paint": "#B00C0A",
                    "width": "0.25"
                  "type": "path"
                  "d": "M27.788,104.832h0.57",
                  "fill": {
                  "name": "path",
                  "stroke": {
                    "paint": "#B00C0A",
                    "width": "0.25"
                  "type": "path"
                  "d": "M27.788,106.315h0.57",
                  "fill": {
                  "name": "path",
                  "stroke": {
                    "paint": "#B00C0A",
                    "width": "0.25"
                  "type": "path"
                  "d": "M27.788,107.684h0.57",
                  "fill": {
                  "name": "path",
                  "stroke": {
                    "paint": "#B00C0A",
                    "width": "0.25"
                  "type": "path"
                  "d": "M27.788,109.053h0.57",
                  "fill": {
                  "name": "path",
                  "stroke": {
                    "paint": "#B00C0A",
                    "width": "0.25"
                  "type": "path"
                  "d": "M27.788,110.651h0.57",
                  "fill": {
                  "name": "path",
                  "stroke": {
                    "paint": "#B00C0A",
                    "width": "0.25"
                  "type": "path"
                  "d": "M27.788,112.02h0.57",
                  "fill": {
                  "name": "path",
                  "stroke": {
                    "paint": "#B00C0A",
                    "width": "0.25"
                  "type": "path"
                  "d": "M27.788,113.389h0.57",
                  "fill": {
                  "name": "path",
                  "stroke": {
                    "paint": "#B00C0A",
                    "width": "0.25"
                  "type": "path"
                  "d": "M22.311,99.126v-1.141",
                  "fill": {
                  "name": "path",
                  "stroke": {
                    "paint": "#666666",
                    "width": "0.25"
                  "type": "path"
                  "d": "M28.245,99.126v-1.141",
                  "fill": {
                  "name": "path",
                  "stroke": {
                    "paint": "#666666",
                    "width": "0.25"
                  "type": "path"
                  "d": "M22.882,99.126v-1.141",
                  "fill": {
                  "name": "path",
                  "stroke": {
                    "paint": "#666666",
                    "width": "0.25"
                  "type": "path"
                  "d": "M24.137,99.126v-1.141",
                  "fill": {
                  "name": "path",
                  "stroke": {
                    "paint": "#666666",
                    "width": "0.25"
                  "type": "path"
                  "d": "M25.62,99.126v-1.141",
                  "fill": {
                  "name": "path",
                  "stroke": {
                    "paint": "#666666",
                    "width": "0.25"
                  "type": "path"
                  "d": "M27.104,99.126v-1.141",
                  "fill": {
                  "name": "path",
                  "stroke": {
                    "paint": "#666666",
                    "width": "0.25"
                  "type": "path"
                  "d": "M28.815,99.126v-1.141",
                  "fill": {
                  "name": "path",
                  "stroke": {
                    "paint": "#666666",
                    "width": "0.25"
                  "type": "path"
                  "d": "M22.161,97.985h6.796",
                  "fill": {
                  "name": "path",
                  "stroke": {
                    "paint": "#B2B2B2",
                    "width": "0.25"
                  "type": "path"
              "id": "Group_Steps",
              "name": "Group_Steps",
              "type": "group"
              "elements": [
                  "elements": [
                      "name": "stop",
                      "offset": "0",
                      "stopColor": "#D11101",
                      "style": {
                      "type": "stop"
                      "name": "stop",
                      "offset": "0.52",
                      "stopColor": "#FF3927",
                      "style": {
                      "type": "stop"
                      "name": "stop",
                      "offset": "1",
                      "style": {
                      "type": "stop"
                  "id": "SVGID_2_",
                  "name": "SVGID_2_",
                  "x1": "23.2239",
                  "x2": "28.0164",
                  "y1": "106.5437",
                  "y2": "106.5437"
                  "d": "M23.224,99.24h4.792v14.606h-4.792V99.24z",
                  "fill": {
                    "url": "url(#SVGID_2_)"
                  "name": "path",
                  "type": "path"
                  "d": "M22.311,99.126h6.504v0.457h-6.504V99.126z",
                  "fill": {
                    "paint": "#E62E1D"
                  "name": "path",
                  "stroke": {
                    "paint": "#E62E1D",
                    "width": "0.25"
                  "type": "path"
                  "d": "M23.224,113.846h4.792v0.228h-4.792V113.846z",
                  "fill": {
                    "paint": "#E62E1D"
                  "name": "path",
                  "stroke": {
                    "paint": "#E62E1D",
                    "width": "0.25"
                  "type": "path"
                  "d": "M28.014,99.583h-4.793h-0.914l0.914,0.228v0.685c0,0,0.859-0.56,2.282-0.575   c1.594-0.018,2.512,0.575,2.512,0.575V99.81l0.799-0.228H28.014z",
                  "fill": {
                    "paint": "#75150C"
                  "name": "path",
                  "type": "path"
              "id": "Group_Base",
              "name": "Group_Base",
              "type": "group"
              "elements": [
                  "elements": [
                      "name": "stop",
                      "offset": "0",
                      "stopColor": "#666666",
                      "style": {
                      "type": "stop"
                      "name": "stop",
                      "offset": "0.5",
                      "style": {
                      "type": "stop"
                      "name": "stop",
                      "offset": "1",
                      "style": {
                      "type": "stop"
                  "id": "SVGID_3_",
                  "name": "SVGID_3_",
                  "x1": "26.9749",
                  "x2": "26.8575",
                  "y1": "42.3079",
                  "y2": "46.1086"
                  "d": "M21.911,45.759c0,0,1.255-0.292,1.255-1.558c0-1.109-0.805-1.751-0.805-1.751h8.901   c0,0,0.859,1.408,0.531,2.408c-0.333,1.015-1.209,1.471-1.209,1.471L21.911,45.759z",
                  "fill": {
                    "url": "url(#SVGID_3_)"
                  "name": "path",
                  "type": "path"
              "id": "Group_Motor",
              "name": "Group_Motor",
              "type": "group"
              "elements": [
                  "elements": [
                      "name": "stop",
                      "offset": "0",
                      "stopColor": "#8C8C8C",
                      "style": {
                      "type": "stop"
                      "name": "stop",
                      "offset": "0.5",
                      "stopColor": "#F2F2F2",
                      "style": {
                      "type": "stop"
                      "name": "stop",
                      "offset": "1",
                      "style": {
                      "type": "stop"
                  "id": "SVGID_4_",
                  "name": "SVGID_4_",
                  "x1": "38.6375",
                  "x2": "37.6864",
                  "y1": "48.2336",
                  "y2": "50.8647"
                  "d": "M22.735,45.336l30.214,10.236l0.229-0.228v-0.571L30.127,44.618l-1.825-0.913l-1.142-0.343   l-2.396,0.229l-1.598,0.114c0,0-0.01,0.724-0.078,0.934C22.963,45.022,22.735,45.336,22.735,45.336z",
                  "fill": {
                    "url": "url(#SVGID_4_)"
                  "name": "path",
                  "type": "path"
                  "elements": [
                      "name": "stop",
                      "offset": "0",
                      "style": {
                      "type": "stop"
                      "name": "stop",
                      "offset": "0.5",
                      "style": {
                      "type": "stop"
                      "name": "stop",
                      "offset": "1",
                      "style": {
                      "type": "stop"
                  "id": "SVGID_5_",
                  "name": "SVGID_5_",
                  "x1": "16.3127",
                  "x2": "18.3404",
                  "y1": "21.6287",
                  "y2": "21.2349"
                  "d": "M22.595,42.614l-9.015-42.5L13.352,0l-0.228,0.343l5.363,33.549l0.342,2.738l0.343,1.369   l1.369,3.081l0.635,1.451c0,0,0.54-0.207,0.734-0.195C22.102,42.348,22.595,42.614,22.595,42.614z",
                  "fill": {
                    "url": "url(#SVGID_5_)"
                  "name": "path",
                  "type": "path"
                  "elements": [
                      "name": "stop",
                      "offset": "0",
                      "style": {
                      "type": "stop"
                      "name": "stop",
                      "offset": "0.5",
                      "style": {
                      "type": "stop"
                      "name": "stop",
                      "offset": "1",
                      "style": {
                      "type": "stop"
                  "id": "SVGID_6_",
                  "name": "SVGID_6_",
                  "x1": "10.0554",
                  "x2": "11.7257",
                  "y1": "60.7947",
                  "y2": "61.9599"
                  "d": "M20.486,44.962L0.002,76.569v0.57h0.342l17.573-23.393l1.483-1.712l0.686-1.255l1.255-3.195   l0.641-1.829c0,0-0.483-0.027-0.79-0.235C20.803,45.257,20.486,44.962,20.486,44.962z",
                  "fill": {
                    "url": "url(#SVGID_6_)"
                  "name": "path",
                  "type": "path"
              "id": "Group_Blades",
              "name": "Group_Blades",
              "style": {
                "animation": "ia_symbolComponent__animate--rotate linear infinite",
                "animation-duration": "1000ms",
                "classes": "",
                "transform-origin": "22px 44px"
              "type": "group"
              "elements": [
                  "cx": 19.9055,
                  "cy": 43.8752,
                  "elements": [
                      "name": "stop",
                      "offset": "0",
                      "style": {
                      "type": "stop"
                      "name": "stop",
                      "offset": "0.5",
                      "stopColor": "#B2B2B2",
                      "style": {
                      "type": "stop"
                      "name": "stop",
                      "offset": "1",
                      "stopColor": "#7F7F7F",
                      "style": {
                      "type": "stop"
                  "id": "SVGID_7_",
                  "name": "SVGID_7_",
                  "r": "3.0742",
                  "type": "radialGradient"
                  "d": "M21.911,42.336c-0.82,0-2.014,0.963-2.024,1.585c-0.011,0.622,1.234,1.838,2.024,1.838   c0.693,0,1.255-0.767,1.255-1.712S22.604,42.336,21.911,42.336z",
                  "fill": {
                    "url": "url(#SVGID_7_)"
                  "name": "path",
                  "type": "path"
              "id": "Group_Center",
              "name": "Group_Center",
              "type": "group"
          "viewBox": "0 0 53.18 113.998"
        "type": "ia.shapes.svg"
    "meta": {
      "name": "root"
    "type": "ia.container.coord"
