Hi guys, I just updated everything on my developer machine:
Ignition: 7.5.6
Java 7.17 (interestingly, on the Gateway > Configure > Status page, it shows my Java Version as: “Sun Microsystems Inc. 1.6.0_18”)
I am getting this dreaded fatal error with the following details, when trying to launch the Designer:[quote]sun.security.validator.ValidatorException: PKIX path validation failed: java.security.cert.CertPathValidatorException: Check netscape extension value failed in certificate
at sun.security.validator.PKIXValidator.doValidate(Unknown Source)
at sun.security.validator.PKIXValidator.engineValidate(Unknown Source)
at sun.security.validator.Validator.validate(Unknown Source)
at com.sun.deploy.security.TrustDecider.validateChain(Unknown Source)
at com.sun.deploy.security.TrustDecider.isAllPermissionGranted(Unknown Source)
at com.sun.javaws.security.AppPolicy.grantUnrestrictedAccess(Unknown Source)
at com.sun.javaws.security.JNLPSignedResourcesHelper.checkSignedResourcesHelper(Unknown Source)
at com.sun.javaws.security.JNLPSignedResourcesHelper.checkSignedResources(Unknown Source)
at com.sun.javaws.Launcher.prepareResources(Unknown Source)
at com.sun.javaws.Launcher.prepareAllResources(Unknown Source)
at com.sun.javaws.Launcher.prepareToLaunch(Unknown Source)
at com.sun.javaws.Launcher.launch(Unknown Source)
at com.sun.javaws.Main.launchApp(Unknown Source)
at com.sun.javaws.Main.continueInSecureThread(Unknown Source)
at com.sun.javaws.Main.access$000(Unknown Source)
at com.sun.javaws.Main$1.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.security.cert.CertPathValidatorException: Check netscape extension value failed in certificate
at sun.security.provider.certpath.PKIXMasterCertPathValidator.validate(Unknown Source)
at sun.security.provider.certpath.PKIXCertPathValidator.doValidate(Unknown Source)
at sun.security.provider.certpath.PKIXCertPathValidator.engineValidate(Unknown Source)
at java.security.cert.CertPathValidator.validate(Unknown Source)
… 20 more
[/quote]
I checked the Java settings:
“Check certificates for revocation using Certificate Revocation Lists (CRLs)”
“Enable online certification validation”
and they were both unchecked.
I only installed the Typical installation, and after getting the certificate error, I uninstalled and reinstalled to no avail.
Any suggestions on how I can fix this? I can’t do any work until it is fixed.
Thanks in advance,
Cas
