Any limit to amount of monitors for Perspective Workstation Multi-mode?
Hi! Is there a limit to how many different monitors can be conifgured to open different pages of Ignition through the Perspective Workstation? My client wants to login once and open four different pages, on on each of four different monitors.
Can this be done through code and startupscripts as well?
Pretty sure there's no limit.
Pretty sure not.
It is a local Workstation configuration to do this, and there's no way for Perspective to command a write to the local disk.
Install Perspective Workstation and then under the project settings you select the Monitors and can specify launch links for each of them.
If you have to use a browser then you could create a launcher file that opens multiple instances each at different URLs, however this would not let them each log on at the same time. Though if you do use an IDP and SSO it could work but they'd still have to click login on each I think but it would automatically authenticate the others with the valid session cookie.
You could create all of the individual client workstation configuration files from perspective though and store them on the gateway to distribute / use
