I have a heap of instances of a particular UDT that do function x on value change. I now also want them to perform the same function every hour on the hour. My capability extends to
- moving as much as I can from the value change script to a shared script
- writing a gateway function (on schedule) that browses the tags of the specified UDT to get all paths for all data points within the UDT instance
- Looping through and running the function
Before I go down this path - does anyone have a better idea?? Any way I can simply force the value change script of tag x to fire?
Any help is appreciated!
Cheers,
Keiran
