I have multiple button that open its own popup.
If I click same button twice. 2 same popup will open.
Is there a way to check that popup already open.
Other than writing to a custom parameter that popup was triggered?
(I've already been doing this on the first button, looking if there is another way)
Perspective or Vision? Select the appropriate tag from the dropdown below your question title. Thanks!
That is for Perspective.. Thanks.
I already used isPopupOpen parameter.
I just can't imagine creating this multiple times.. thought maybe there is another way.
When you open a popup if you specify a unique Id then only one popup with that Id will open.
You mean, if I run two "openPopup" command with the same ID. The 2nd command will not open another popup?
edit:
Ohh.. That worked! Thanks.
