Apache Log4J Vulnerability - CVE-2021-44228
On December 9th, 2021, a new vulnerability was reported (CVE-2021-44228) against a common Java logging library, “log4j”. This vulnerability makes affected systems susceptible to having remote attackers be able to run malicious programs on said systems. This is also known as an RCE, or Remote Code Execution attack.
Inductive Automation has conducted a full audit of Ignition’s direct and transitive dependencies to confirm that log4j is not used or included in any supported or unsupported release of Ignition, and as such it is not vulnerable to the RCE outlined in CVE-2021-44228. This includes LTS versions 7.9 and 8.1, as well as all past and non-LTS versions. While Ignition versions 7.8 and prior did use log4j for its logging backend, the version used (1.2.x) is not affected.
No action is required by any Ignition user on any version of Ignition, LTS or not, to mitigate the effects of CVE-2021-44228.
Great! But is it possible to use log4j in third-party modules? if yes , will that be unsafe?
Module install files are just zip files. You can just open them and look.
Over on their forum, CirrusLink confirmed that their Ignition modules and Chariot MQTT broker are safe.
Modules from Kymera Systems are also not affected by the Log4J vulnerability.
So too with all of Automation Professionals’ modules.
I just received a report from a customer that use Crowdstrike for vulnerability management, and they provided the following details in their report:
Here are the details of Log4j that have been detected -
Version: log4j-over-slf4j-1.7.26.
It looks like the log4j library is detected here:
lib/core/common/log4j-over-slf4j-1.7.26.jar
This is on Ignition 8.1.7.
Sounds like the vulnerability is only for log4j versions 2.0.1 to 2.15.0, which would make this version used by Ignition ok?
False positive.
I was asked about this by our IT security department a few days after the venerability was discovered. Just wanted to give a shout out to IA, it was super easy to find and share this post which alleviated immediate concern and probably installed greater approval in the Ignition platform from their perspective!
