So I have successfully created a script that runs from a button on a windows.
When I moved the script to a gateway Event Scripts on a tag change… I get this error
"com.inductiveautomation.ignition.common.script.JythonExecException: Traceback (most recent call last): File “”, line 1, in ImportError: No module named poi "
from this line of code.
“from org.apache.poi.ss.usermodel import Row,Cell”
That it’s even available in the client and designer is a quirk of how class paths work in the client and the fact that you have the reporting module installed.
accyroy I’ll have to do some digging because I know I’ve got a document somewhere. The github repository is: https://github.com/TamakiControl/TamakiScripting if you want to look for now. I’ll find that document and upload it here…
