Apex Chart - change color between curves
I would like to color dynamically area between two curves. If blue curve is under the red curve --> green.
If blue curve is above red curve --> red
Is it possible with ApexChart ?
An exemple below :
Were you able to do this? I would like to do something similar using area in a ApexChart
Not yet
You can do this with a rangeArea chart:
