Apex chart for Edge panel
Hi , as Edge pannel used for ui on Edge .. is there any plan to add Apex module to Edge ?
what about if as end user create a module for integration with some special hardware on Edge ??
Third party modules are not allowed on Edge, other than the Cirrus Link modules.
If you have special requirements that can only be solved with a 3rd party module, you must use standard Ignition, not Edge.
Not true anymore, though vetting is required. Probably won't happen for an open-source module that anyone can modify and build.
