Apex Module Line Chart
i noticed Apex line chart loaded after user interaction on the view ? did any once face same issue ?
i tested with different Ignition versions ( 11,12,13) and all are same issue .
i am using Apex Module version(1.0.5) Releases · Kyvis-Labs/ignition-apexcharts-module · GitHub
eyCU8tlhYy
I have same problem may be @Travis.Cox can help on this as he did the last changes to the module.
I know this is a old problem, but I'm having the same issue. Has anybody found a fix?
Has anybody else experienced this issue or have any other suggestions? I am experiencing the same issue on an Apex line chart on a very inconsistent basis. Basically the entire view will load but one random Apex line chart will be completely missing, X-Axis/Y-Axis/Title/Data and all. If I zoom in and back out the chart is re-triggered and then renders normally.
As troubleshooting steps I have set all objects on the view to a grow/shrink of 0 and set hard coded the size of all components and flex containers on the view. I have also taken care to make sure that the charts are getting passed the data at the exact same time. The last thing I did was turn off the animation on the charts to load the data immediately.
I am running Ignition 8.1.44 and Apex Module 1.0.22.
Thanks in advance!
