API connection error via scheduled event script
Hello,
in a scheduled event script, i try to connect via an API with system.net.httpGet().
When i try to connect, suddenly the designer i can't connect to the gateway anymore. I have "Gateway connection lost - post error, error code = 400"
Below the script i try to run.
Basycally i want to connect to an API and then searching the intersection between rows and column, copy the respective value, and writing it into a tag.
Appreciate if anybody could help.
from datetime import datetime, timedelta
# API URL
url = "http://abc"
# Dictionary of columns and corresponding tags
colonne_tag = {
    "column_name": "xxx/Consumi/kWh_60"
# Request data from API
response = system.net.httpGet(url)
if response and response.strip():
    # Get the current time minus two hours
    ora_target = (datetime.now() - timedelta(hours=2)).strftime("%d-%m-%Y;%H:00")
    # Split data into rows using CRLF
    righe = response.split("\r\n")
    # Check if there is data and at least a header row
    if len(righe) >= 2:
        # Get the header and map columns
        intestazione = righe[0].split("\t")
        colonne_mappa = {colonna: idx for idx, colonna in enumerate(intestazione) if colonna in colonne_tag}
        # Search for the row with the target date and time
        for riga in righe[1:]:
            # Ignore rows containing "!"
            if "!" in riga:
                continue
            colonne = riga.split("\t")
            if len(colonne) == 22 and colonne[0] + ";" + colonne[1] == ora_target:
                for colonna, indice in colonne_mappa.items():
                    try:
                        valore_colonna = colonne[indice].replace(",", ".")  # Convert value to standard numeric format
                        valore_float = float(valore_colonna)
                        # Write the value to the tag with the specific timestamp
                        system.tag.storeTagHistory("prov:Local_SQL", [colonne_tag[colonna]], [datetime.now() - timedelta(hours=2)], [valore_float])
                    except (ValueError, IndexError):
                        continue  # Ignore conversion or index errors
What does the gateway's CPU and memory usage look like when this scheduled event is running? How large is the response object from this API?
gateway's CPU and memory usage looks regular, without peaks.
The API answer is below.
API answer
12-01-2025;00:00;38,50; ;18,70; ;32,00; ;44,00; ;20,00; ;25,00; ;29,00; ;6,00; ;75,00; ;62,00; ;331,50; 12-01-2025;01:00;37,50; ;18,80; ;31,00; ;42,00; ;19,00; ;27,00; ;28,00; ;6,00; ;73,00; ;62,00; ;325,50; 12-01-2025;02:00;38,40; ;18,60; ;32,00; ;42,00; ;20,00; ;25,00; ;28,00; ;6,00; ;71,00; ;61,00; ;323,40; 12-01-2025;03:00;37,10; ;18,90; ;31,00; ;43,00; ;19,00; ;27,00; ;27,00; ;6,00; ;68,00; ;60,00; ;318,10; 12-01-2025;04:00;38,10; ;18,60; ;32,00; ;43,00; ;21,00; ;25,00; ;28,00; ;6,00; ;70,00; ;61,00; ;324,10; 12-01-2025;05:00;38,70; ;18,60; ;31,00; ;43,00; ;18,00; ;27,00; ;27,00; ;6,00; ;68,00; ;61,00; ;319,70; 12-01-2025;06:00;37,40; ;18,70; ;33,00; ;42,00; ;21,00; ;25,00; ;29,00; ;6,00; ;68,00; ;61,00; ;322,40; 12-01-2025;07:00;38,00; ;18,90; ;31,00; ;43,00; ;19,00; ;27,00; ;28,00; ;6,00; ;68,00; ;60,00; ;320,00; 12-01-2025;08:00;37,70; ;18,70; ;32,00; ;43,00; ;19,00; ;25,00; ;28,00; ;6,00; ;69,00; ;62,00; ;321,70; 12-01-2025;09:00;38,20; ;18,70; ;32,00; ;42,00; ;21,00; ;27,00; ;29,00; ;6,00; ;72,00; ;61,00; ;328,20; 12-01-2025;10:00;38,50; ;18,80; ;32,00; ;42,00; ;19,00; ;26,00; ;28,00; ;6,00; ;70,00; ;61,00; ;322,50; 12-01-2025;11:00;37,90; ;18,40; ;31,00; ;43,00; ;21,00; ;25,00; ;30,00; ;6,00; ;72,00; ;62,00; ;327,90; 12-01-2025;12:00;38,60; ;18,80; ;32,00; ;44,00; ;19,00; ;26,00; ;30,00; ;7,00; ;73,00; ;61,00; ;330,60; 12-01-2025;13:00;37,90; ;18,70; ;32,00; ;42,00; ;20,00; ;27,00; ;28,00; ;6,00; ;71,00; ;61,00; ;324,90; 12-01-2025;14:00;36,80; ;18,70; ;31,00; ;43,00; ;19,00; ;25,00; ;28,00; ;5,00; ;72,00; ;60,00; ;319,80; 12-01-2025;15:00;38,80; ;18,70; ;33,00; ;42,00; ;20,00; ;27,00; ;29,00; ;7,00; ;72,00; ;63,00; ;331,80; 12-01-2025;16:00;38,80; ;18,70; ;31,00; ;43,00; ;19,00; ;25,00; ;29,00; ;6,00; ;72,00; ;60,00; ;323,80; 12-01-2025;17:00;37,60; ;18,60; ;32,00; ;42,00; ;21,00; ;27,00; ;28,00; ;6,00; ;72,00; ;62,00; ;327,60; 12-01-2025;18:00;38,30; ;18,50; ;32,00; ;43,00; ;20,00; ;25,00; ;30,00; ;6,00; ;71,00; ;62,00; ;327,30; 12-01-2025;19:00;38,10; ;19,00; ;32,00; ;44,00; ;19,00; ;26,00; ;30,00; ;7,00; ;73,00; ;61,00; ;330,10; 12-01-2025;20:00;40,00; ;21,20; ;32,00; ;42,00; ;19,00; ;27,00; ;30,00; ;6,00; ;72,00; ;63,00; ;331,00; 12-01-2025;21:00;65,20; ;46,70; ;46,00; ;54,00; ;21,00; ;57,00; ;28,00; ;10,00; ;179,00; ;114,00; ;574,20; 12-01-2025;22:00;120,80; ;148,10; ;62,00; ;130,00; ;19,00; ;125,00; ;41,00; ;18,00; ;220,00; ;123,00; ;858,80; 12-01-2025;23:00;131,50; ;152,10; ;77,00; ;162,00; ;20,00; ;141,00; ;42,00; ;18,00; ;230,00; ;128,00; ;949,50; 13-01-2025;00:00;131,30; ;73,10; ;115,00; ;171,00; ;20,00; ;161,00; ;49,00; ;25,00; ;236,00; ;126,00; ;1034,30; 13-01-2025;01:00;132,80; ;151,80; ;115,00; ;178,00; ;19,00; ;151,00; ;49,00; ;24,00; ;234,00; ;127,00; ;1029,80; 13-01-2025;02:00;131,30; ;120,90; ;120,00; ;173,00; ;21,00; ;156,00; ;48,00; ;26,00; ;233,00; ;126,00; ;1034,30; 13-01-2025;03:00;119,30; ;150,80; ;115,00; ;171,00; ;19,00; ;160,00; ;46,00; ;26,00; ;233,00; ;126,00; ;1015,30; 13-01-2025;04:00;131,70; ;149,10; ;112,00; ;174,00; ;20,00; ;155,00; ;46,00; ;26,00; ;231,00; ;127,00; ;1022,70; 13-01-2025;05:00;136,30; ;151,00; ;112,00; ;172,00; ;19,00; ;156,00; ;73,00; ;27,00; ;229,00; ;125,00; ;1049,30; 13-01-2025;06:00;121,50; ;152,80; ;118,00; ;178,00; ;21,00; ;157,00; ;78,00; ;24,00; ;235,00; ;128,00; ;1060,50; 13-01-2025;07:00;123,40; ;158,70; ;120,00; ;184,00; ;19,00; ;157,00; ;83,00; ;25,00; ;236,00; ;132,00; ;1079,40; 13-01-2025;08:00;134,50; ;156,90; ;119,00; ;183,00; ;19,00; ;159,00; ;79,00; ;24,00; ;239,00; ;134,00; ;1090,50; 13-01-2025;09:00;135,30; ;158,70; ;120,00; ;185,00; ;21,00; ;154,00; ;80,00; ;25,00; ;234,00; ;138,00; ;1092,30; 13-01-2025;10:00;124,30; ;156,80; ;109,00; ;174,00; ;19,00; ;142,00; ;79,00; ;23,00; ;239,00; ;133,00; ;1042,30; 13-01-2025;11:00;113,90; ;155,00; ;115,00; ;185,00; ;26,00; ;160,00; ;73,00; ;22,00; ;216,00; ;131,00; ;1041,90; 13-01-2025;12:00;140,20; ;153,60; ;119,00; ;179,00; ;24,00; ;138,00; ;55,00; ;26,00; ;180,00; ;132,00; ;993,20; 13-01-2025;13:00;131,90; ;153,00; ;118,00; ;178,00; ;25,00; ;133,00; ;52,00; ;25,00; ;178,00; ;141,00; ;981,90; 13-01-2025;14:00;130,20; ;151,80; ;118,00; ;172,00; ;23,00; ;138,00; ;49,00; ;24,00; ;183,00; ;130,00; ;967,20; 13-01-2025;15:00;134,40; ;150,10; ;118,00; ;183,00; ;24,00; ;155,00; ;52,00; ;24,00; ;180,00; ;78,00; ;948,40; 13-01-2025;16:00;135,20; ;152,60; ;119,00; ;180,00; ;25,00; ;158,00; ;51,00; ;24,00; ;175,00; ;96,00; ;963,20; 13-01-2025;17:00;135,90; ;149,90; ;116,00; ;180,00; ;24,00; ;123,00; ;51,00; ;24,00; ;181,00; ;131,00; ;965,90; 13-01-2025;18:00;136,60; ;140,00; ;116,00; ;184,00; ;26,00; ;52,00; ;55,00; ;25,00; ;177,00; ;133,00; ;904,60; 13-01-2025;19:00;137,30; ;149,20; ;112,00; ;176,00; ;24,00; ;41,00; ;53,00; ;23,00; ;181,00; ;132,00; ;879,30; 13-01-2025;20:00;137,10; ;131,70; ;99,00; ;185,00; ;24,00; ;38,00; ;53,00; ;17,00; ;181,00; ;132,00; ;866,10; 13-01-2025;21:00;136,40; ;140,80; ;52,00; ;182,00; ;25,00; ;42,00; ;52,00; ;9,00; ;188,00; ;130,00; ;816,40; 13-01-2025;22:00;119,50; ;108,30; ;38,00; ;174,00; ;24,00; ;45,00; ;53,00; ;3,00; ;211,00; ;131,00; ;798,50; 13-01-2025;23:00;134,60; ;161,00; ;38,00; ;169,00; ;24,00; ;47,00; ;50,00; ;3,00; ;227,00; ;131,00; ;823,60;
when i connect and try to connect from the script console, the gateway disconnect after 20/30 seconds and i get the thread below.
Thread [webserver-6506734] id=6506734, (TIMED_WAITING for java.util.concurrent.SynchronousQueue$TransferStack@2ae6330b)
java.base@17.0.10/jdk.internal.misc.Unsafe.park(Native Method)
java.base@17.0.10/java.util.concurrent.locks.LockSupport.parkNanos(Unknown Source)
java.base@17.0.10/java.util.concurrent.SynchronousQueue$TransferStack.transfer(Unknown Source)
java.base@17.0.10/java.util.concurrent.SynchronousQueue.poll(Unknown Source)
app//org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.reservedWait(ReservedThreadExecutor.java:325)
app//org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:401)
app//org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:969)
app//org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.doRunJob(QueuedThreadPool.java:1194)
app//org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1149)
java.base@17.0.10/java.lang.Thread.run(Unknown Source)
i have also this error
14:11:15.558 [DesignerExecEngine-3] WARN com.inductiveautomation.ignition.client.gateway_interface.GatewayConnectionManager -- Connection to Gateway lost, due to exception.
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Connessione interrotta dal software del computer host
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:360)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:556)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:292)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:287)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:967)
	at com.inductiveautomation.ignition.client.tags.impl.ClientTagSubscriptionManager.syncSubscriptions(ClientTagSubscriptionManager.java:331)
	at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:593)
	at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source)
Caused by: java.net.SocketException: Connessione interrotta dal software del computer host
	at java.base/sun.nio.ch.NioSocketImpl.implRead(Unknown Source)
	at java.base/sun.nio.ch.NioSocketImpl.read(Unknown Source)
	at java.base/sun.nio.ch.NioSocketImpl$1.read(Unknown Source)
	at java.base/java.net.Socket$SocketInputStream.read(Unknown Source)
	at java.base/sun.security.ssl.SSLSocketInputRecord.read(Unknown Source)
	at java.base/sun.security.ssl.SSLSocketInputRecord.readHeader(Unknown Source)
	at java.base/sun.security.ssl.SSLSocketInputRecord.bytesInCompletePacket(Unknown Source)
	at java.base/sun.security.ssl.SSLSocketImpl.readApplicationRecord(Unknown Source)
	at java.base/sun.security.ssl.SSLSocketImpl$AppInputStream.read(Unknown Source)
	at java.base/java.io.BufferedInputStream.fill(Unknown Source)
	at java.base/java.io.BufferedInputStream.read1(Unknown Source)
	at java.base/java.io.BufferedInputStream.read(Unknown Source)
	at java.base/sun.net.www.http.HttpClient.parseHTTPHeader(Unknown Source)
	at java.base/sun.net.www.http.HttpClient.parseHTTP(Unknown Source)
	at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream0(Unknown Source)
	at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
	at java.base/java.net.HttpURLConnection.getResponseCode(Unknown Source)
	at java.base/sun.net.www.protocol.https.HttpsURLConnectionImpl.getResponseCode(Unknown Source)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:450)
	... 11 common frames omittedtype or paste code here
An established connection was aborted by the software in your host machine
Something on your network (IT provided "security" software, most likely) is interrupting the connection. Not an Ignition issue.
