App/home and web/home
What is the difference between “localhost:8088/app/home” and “localhost:8088/web/home”? Why can I only open the first one?
i I don’t have the Ignition modules folder in my installation directory.
I'm not sure what you expect? URLs in a webserver are often synthetic--not corresponding to file system folders at all--and filesystem folders aren't exposed unless deliberately so.
Also, look for the modules folder under the user-lib folder.
Yes, I found this modules file under the user-lib folder. I noticed that its layout is different from what was shown in the training video and from what I see when opening Ignition Vision. thanks pturmel
Make sure you are watching training videos matching the version of Ignition (8.1 vs 8.3, etc.) that you are using. The versions might have some significant sifferences, including:
ok, thanks chris.
