Hi!
Ignition won’t start if you have Java 8.25 installed in OSX 10.10.
Ignition seems to need a minor Java version (7.71?).
Any solutions?
This error was from the wrapper log? Can you upload the log?
Hi James,
No - it didn’t come from there.
Actually I uninstalled Java 8 and installed Java 7.
Problem remains.
When I try to startup ignition (From Terminal *)there’s a Java window with comment “Java Run-time should be installed…” while it is installed.
I mean, Ignition demo starts and run ok. This is same with both of Java versions.
*) In terminal with basic command “ignition start” there’s reply “Starting Ignition Gateway” and “Waiting for Ignition Gateway” while nothing really happens. With sudo command the reply is the same and it tries to start with Java window comments.
I’m not too familiar with osx terminal and don’t know if there is a log somewhere. Maybe you can tell me?
I try to attach few screens from start up sequence…
- K
Ignition runs fine on OS X with Java 8 - there’s something else wrong here.
You’ll need to attach or send us the wrapper.log file to figure out why it’s not starting for you.
It works now. After installing Java 8 JDK!
Not JRE…
That is all I’ve done here.
Here’s a sample from system monitor since I still don’t know how to get a wrapper log(!):
Ignition-Gateway:
Analysis of sampling ignition-gateway (pid 224) every 1 millisecond
Process: ignition-gateway [224]
Path: /usr/local/ignition/ignition-gateway
Load Address: 0x100000000
Identifier: ignition-gateway
Version: ???
Code Type: X86-64
Parent Process: launchd [1]
Date/Time: 2014-11-02 12:03:01.958 +0200
OS Version: Mac OS X 10.10 (14A389)
Report Version: 7
Analysis Tool: /usr/bin/sample
Call graph:
2840 Thread_950 DispatchQueue_1: com.apple.main-thread (serial)
+ 2840 start (in ignition-gateway) + 33 [0x100000db1]
+ 2840 _start (in ignition-gateway) + 227 [0x100000e95]
+ 2840 main (in ignition-gateway) + 1428 [0x10001f024]
+ 2840 wrapperRunConsole (in ignition-gateway) + 199 [0x100010417]
+ 2834 wrapperEventLoop (in ignition-gateway) + 4554 [0x10001a63a]
+ ! 2834 wrapperSleep (in ignition-gateway) + 130 [0x10001d2c2]
+ ! 2833 __semwait_signal (in libsystem_kernel.dylib) + 10 [0x7fff8f6b9486]
+ ! 1 nanosleep (in libsystem_c.dylib) + 199 [0x7fff88126f7d]
+ ! 1 cerror (in libsystem_kernel.dylib) + 0 [0x7fff8f6b4cc8]
+ 4 wrapperEventLoop (in ignition-gateway) + 412 [0x10001960c]
+ ! 2 wrapperReadChildOutput (in ignition-gateway) + 382 [0x10000f5ae]
+ ! : 2 read (in libsystem_kernel.dylib) + 10 [0x7fff8f6ba67e]
+ ! 1 wrapperReadChildOutput (in ignition-gateway) + 49 [0x10000f461]
+ ! : 1 gettimeofday (in libsystem_c.dylib) + 1 [0x7fff880b80ee]
+ ! 1 wrapperReadChildOutput (in ignition-gateway) + 208 [0x10000f500]
+ 1 wrapperEventLoop (in ignition-gateway) + 503 [0x100019667]
+ ! 1 __recvfrom (in libsystem_kernel.dylib) + 10 [0x7fff8f6b9336]
+ 1 wrapperEventLoop (in ignition-gateway) + 505 [0x100019669]
2840 Thread_968
2840 thread_start (in libsystem_pthread.dylib) + 13 [0x7fff808e34b1]
2840 _pthread_start (in libsystem_pthread.dylib) + 176 [0x7fff808e5279]
2840 _pthread_body (in libsystem_pthread.dylib) + 131 [0x7fff808e52fc]
2840 timerRunner (in ignition-gateway) + 146 [0x10001f1f2]
2839 wrapperSleep (in ignition-gateway) + 130 [0x10001d2c2]
! 2837 __semwait_signal (in libsystem_kernel.dylib) + 10 [0x7fff8f6b9486]
! 2 nanosleep (in libsystem_c.dylib) + 199 [0x7fff88126f7d]
! 2 cerror (in libsystem_kernel.dylib) + 20 [0x7fff8f6b4cdc]
! 2 cerror_nocancel (in libsystem_kernel.dylib) + 20 [0x7fff8f6b4cb7]
1 wrapperSleep (in ignition-gateway) + 132 [0x10001d2c4]
Total number in stack (recursive counted multiple, when >=5):
Sort by top of stack, same collapsed (when >= 5):
__semwait_signal (in libsystem_kernel.dylib) 5670
Binary Images:
0x100000000 - 0x10005ffff +ignition-gateway (???) /usr/local/ignition/ignition-gateway
0x7fff6f9aa000 - 0x7fff6f9e0837 dyld (0.0 - ???) <4696A982-1500-34EC-9777-1EF7A03E2659> /usr/lib/dyld
0x7fff8030d000 - 0x7fff80312ff7 libmacho.dylib (862) <126CA2ED-DE91-308F-8881-B9DAEC3C63B6> /usr/lib/system/libmacho.dylib
0x7fff808e2000 - 0x7fff808ebfff libsystem_pthread.dylib (105.1.4) <26B1897F-0CD3-30F3-B55A-37CB45062D73> /usr/lib/system/libsystem_pthread.dylib
0x7fff80bdd000 - 0x7fff80bdffff libsystem_configuration.dylib (699.1.5) <9FBA1CE4-97D0-347E-A443-93ED94512E92> /usr/lib/system/libsystem_configuration.dylib
0x7fff80be0000 - 0x7fff80be0ff7 libkeymgr.dylib (28) <77845842-DE70-3CC5-BD01-C3D14227CED5> /usr/lib/system/libkeymgr.dylib
0x7fff811d8000 - 0x7fff81210ffb libsystem_network.dylib (411) /usr/lib/system/libsystem_network.dylib
0x7fff8135e000 - 0x7fff813d4fe7 libcorecrypto.dylib (233.1.2) /usr/lib/system/libcorecrypto.dylib
0x7fff8186c000 - 0x7fff8186dffb libremovefile.dylib (35) <3485B5F4-6CE8-3C62-8DFD-8736ED6E8531> /usr/lib/system/libremovefile.dylib
0x7fff819fc000 - 0x7fff81aeeff7 libiconv.2.dylib (42) <2A06D02F-8B76-3864-8D96-64EF5B40BC6C> /usr/lib/libiconv.2.dylib
0x7fff81bf6000 - 0x7fff81bf8ff7 libsystem_sandbox.dylib (358.1.1) /usr/lib/system/libsystem_sandbox.dylib
0x7fff81cdd000 - 0x7fff81cf9ff7 libsystem_malloc.dylib (53.1.1) <19BCC257-5717-3502-A71F-95D65AFA861B> /usr/lib/system/libsystem_malloc.dylib
0x7fff81f95000 - 0x7fff81fa6ff7 libsystem_coretls.dylib (35.1.2) /usr/lib/system/libsystem_coretls.dylib
0x7fff8206f000 - 0x7fff8206fff7 liblaunch.dylib (559.1.22) <8A988924-8BE7-35FE-BF7D-322E90EFE49E> /usr/lib/system/liblaunch.dylib
0x7fff82276000 - 0x7fff82278ff7 libquarantine.dylib (76) /usr/lib/system/libquarantine.dylib
0x7fff8268c000 - 0x7fff8268dff7 libsystem_blocks.dylib (65) <9615D10A-FCA7-3BE4-AA1A-1B195DACE1A1> /usr/lib/system/libsystem_blocks.dylib
0x7fff829be000 - 0x7fff829c6fff libsystem_dnssd.dylib (561.1.1) <62B70ECA-E40D-3C63-896E-7F00EC386DDB> /usr/lib/system/libsystem_dnssd.dylib
0x7fff82c41000 - 0x7fff82c44ff7 libdyld.dylib (353.2.1) <19FAF435-C165-3374-9DEF-D7BBA7D61DB6> /usr/lib/system/libdyld.dylib
0x7fff83288000 - 0x7fff83289fff libSystem.B.dylib (1213) /usr/lib/libSystem.B.dylib
0x7fff8340e000 - 0x7fff83454ff7 libauto.dylib (186) /usr/lib/libauto.dylib
0x7fff83525000 - 0x7fff8354dfff libxpc.dylib (559.1.22) <9437C02E-A07B-38C8-91CB-299FAA63083D> /usr/lib/system/libxpc.dylib
0x7fff83b32000 - 0x7fff83b3afff libsystem_platform.dylib (63) <64E34079-D712-3D66-9CE2-418624A5C040> /usr/lib/system/libsystem_platform.dylib
0x7fff83b3d000 - 0x7fff83b43fff libsystem_trace.dylib (72.1.3) /usr/lib/system/libsystem_trace.dylib
0x7fff83b44000 - 0x7fff83b48fff libsystem_stats.dylib (163.1.4) <1DB04436-5974-3F16-86CC-5FF5F390339C> /usr/lib/system/libsystem_stats.dylib
0x7fff8410e000 - 0x7fff84124ff7 libsystem_asl.dylib (267) /usr/lib/system/libsystem_asl.dylib
0x7fff8422b000 - 0x7fff8422dff7 libsystem_coreservices.dylib (9) <41B7C578-5A53-31C8-A96F-C73E030B0938> /usr/lib/system/libsystem_coreservices.dylib
0x7fff845d2000 - 0x7fff845d3fff libsystem_secinit.dylib (18) <581DAD0F-6B63-3A48-B63B-917AF799ABAA> /usr/lib/system/libsystem_secinit.dylib
0x7fff873b0000 - 0x7fff87404fff libc++.1.dylib (120) <1B9530FD-989B-3174-BB1C-BDC159501710> /usr/lib/libc++.1.dylib
0x7fff8779c000 - 0x7fff877a3ff7 libcompiler_rt.dylib (35) /usr/lib/system/libcompiler_rt.dylib
0x7fff87f4a000 - 0x7fff87f4bfff libDiagnosticMessagesClient.dylib (100) <2EE8E436-5CDC-34C5-9959-5BA218D507FB> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff880a8000 - 0x7fff88134fff libsystem_c.dylib (1044.1.2) /usr/lib/system/libsystem_c.dylib
0x7fff88322000 - 0x7fff8834afff libsystem_info.dylib (459) /usr/lib/system/libsystem_info.dylib
0x7fff899b3000 - 0x7fff899bbffb libcopyfile.dylib (118.1.2) <0C68D3A6-ACDD-3EF3-991A-CC82C32AB836> /usr/lib/system/libcopyfile.dylib
0x7fff8a27c000 - 0x7fff8a2a6ff7 libdispatch.dylib (442.1.4) <502CF32B-669B-3709-8862-08188225E4F0> /usr/lib/system/libdispatch.dylib
0x7fff8b02c000 - 0x7fff8b030fff libcache.dylib (69) <45E9A2E7-99C4-36B2-BEE3-0C4E11614AD1> /usr/lib/system/libcache.dylib
0x7fff8b480000 - 0x7fff8b485ff7 libunwind.dylib (35.3) /usr/lib/system/libunwind.dylib
0x7fff8b486000 - 0x7fff8b486ff7 libunc.dylib (29) <5676F7EA-C1DF-329F-B006-D2C3022B7D70> /usr/lib/system/libunc.dylib
0x7fff8cf3d000 - 0x7fff8d122267 libobjc.A.dylib (646) <3B60CD90-74A2-3A5D-9686-B0772159792A> /usr/lib/libobjc.A.dylib
0x7fff8d7a3000 - 0x7fff8d7acff7 libsystem_notify.dylib (133.1.1) <61147800-F320-3DAA-850C-BADF33855F29> /usr/lib/system/libsystem_notify.dylib
0x7fff8e95b000 - 0x7fff8e986fff libc++abi.dylib (125) <88A22A0F-87C6-3002-BFBA-AC0F2808B8B9> /usr/lib/libc++abi.dylib
0x7fff8e987000 - 0x7fff8e98dff7 libsystem_networkextension.dylib (167.1.10) <29AB225B-D7FB-30ED-9600-65D44B9A9442> /usr/lib/system/libsystem_networkextension.dylib
0x7fff8eb30000 - 0x7fff8eb60fff libsystem_m.dylib (3086.1) <1E12AB45-6D96-36D0-A226-F24D9FB0D9D6> /usr/lib/system/libsystem_m.dylib
0x7fff8f6a3000 - 0x7fff8f6c0fff libsystem_kernel.dylib (2782.1.97) <93E0E0A9-75B6-3904-BB4E-4BC7C05F4B6B> /usr/lib/system/libsystem_kernel.dylib
0x7fff8fc04000 - 0x7fff8fc0ffff libcommonCrypto.dylib (60061) /usr/lib/system/libcommonCrypto.dylib
