When I active the Expose Configured Tags in Ignition and connect with an OPC-UA client (UAExpert from Unified Automation) on a Gateway with multiple NIC, the ApplicationUri returned by Ignition is a bit strange.
I connect on the master gw (192.168.100.119) and the IP in the URI is the IP of the backup gw (192.168.100.118)
When I connect to the backup GW the ip is the same (192.168.100.118) in the URI
Initialy I use the backup machine to create my project, and then load the backup on the master and set the redundancy.
Can we set this parameters in Ignition ?
