Approve/Reset Setpoint Change
Hi all,
I am using the vision window and the "numeric text field’ component. I want to have a popup to appear after the value in the numeric text field is changed and “Enter” key is pressed. The popup says a message similar to “Are you sure you want to make the change?” There will be a “Yes” button and a “No” button. If “Yes” is pressed then the value will change. If “No” is pressed then the value will reset to the original value.
What is the best way to develop the approving and resetting of the value change?
Thanks in advance
