I am wondering how to revert colors to the default theme colors.
I have a binding on textStyle.color, when there is a alarm state I set the color to red using a “if true then map to ‘red’ “.
My question is how do I revert this to a theme color? Obviously mapping it to black or white would work only when the user is on the “correct” theme.
I tried “default” and that does not seem to work it just holds the red after the alarm has cleared.
The proper CSS way to do this would be to create a Perspective style class alarmState where you set the text color. Rather than red I would use a built-in theme color --error. When using this in your style class you will use the var(--error) syntax.
Then create an expression binding on the label's style.classes:
if(
{[default]myAlarm}, // replace with your alarm indicator.
'alarmState',
This will change with theme selection to match everything else which you will naturally have defined with theme colors (won't you?).
Thanks, while messing with that I also learned you can go to Map and change the output types which includes a selection for style class.
