I have a view that I want to use in multiple ways, it's nothing more than a popup with a message and two commands, one that closes the view itself and one that I want to parameterize so that I can use it multiple times.
- Pass a parameter containing some code or other into the popup.
- In the popup,
If required, add an expression binding to the button's text property to change the text.
On the button event set up something like this.
- On the components or views to react to the message you need to add a message handler. Read the doc and watch the video.
Thank you i will try it
