Asynchronously execute Stored Procedures via Gateway Script
I want to execute two Stored Procedures asynchronously i.e., one after the another.
SP_COATING_DASH_2 executes in 4.6 secs and
SP_SET_LOCK_DASH executes in less than 1 sec.
In my script, I have:
## Code for running SP's to DAILY_DASH
## At 11:59 AM on every Thursday Night
## The gateway script should check every one min OR @60,000 ms
import system
import time
from datetime import datetime
dateFormat ="%Y-%m-%d %H:%M:%S"
currentDate = system.db.dateFormat(system.tag.read("CurrentDateTime").value,"yyyy-MM-dd HH:mm:ss") ## Get date from the Tag
## pythonDate = datetime.now();
currentDatePython = datetime.strptime(currentDate,dateFormat) ## Convert the date to datetime format
currentDayOfWeek = currentDatePython.weekday() ##{Mon = 0, Tue=1, Wed = 2, *Thu = 3*, Fri = 4, Sat = 5, Sun = 6}
currentHour = currentDatePython.hour ## Range(0,24)
currentMin = currentDatePython.minute ## Range (0,60)
currentSec = currentDatePython.second ## Range (0,60) ## We may not need seconds in this code
if currentDayOfWeek == 3: ##Thursday
	if currentHour == 23: ## 11 AM
		if currentMin == 59: ## 11:59 AM
			##Create SP Calls here
			coater = system.db.createSProcCall("SP_COATING_DASH_2","OPFIS")
			setLockToOne = system.db.createSProcCall("SP_SET_LOCK_DASH","OPFIS")
			## Add SP Calls for other Stored Procedures as well here
			system.db.execSProcCall(coater)
			## The lock should be set to 1 after all these stored procedures are called!
			time.sleep(1) # sleep for 1s
			system.db.execSProcCall(setLockToOne) ## Set Lock = 1 to all the rows
Should I use the time.sleep function (or) execute it using the invokeLater? This is a gateway timer script that runs @ every 60,000 ms and checks whether it is Thursday, 11:59 AM and updates the tables!
Hello oxanemi,
Your script is executing the stored procedures synchronously, not asynchronously. To execute them asynchronously you need to use system.util.invokeAsynchronous.
You can’t use system.util.invokeLater in this script because this function only exists in Clients and Designers. It does not exist in the Gateway scope. You can use time.sleep(1).
Best,
