Attempting to Connect to a Firebird Database
I have created a local Firebird database. That database is located at D:\firebirdtest\TEST.FDB. I added the Firebird driver, provided the correct .jar file, and then I created a database connection with the connect URL as ‘D:\firebirdtest\TEST.FDB’. The database then appears with an ERROR status, reading “Cannot create JDBC driver of class ‘org.firebirdsql.jdbc.FBDriver’ for connect URL ‘D:\firebirdtest\test.fdb'“.
I’ve attempted other connect URL’s and get a connection-based error, leading me to believe that I may have set up the driver wrong, but I am open to other possibilities. Still learning to use Ignition and would very much appreciate some help.
Your new database connection is set up to use the Firebird JDBC driver profile you set up, correct? What's the status of that JDBC driver you added?
The status on the Firebird driver is “Installed”. The database connection is set to use the Firebird driver.
I believe I’ve sorted the driver/connect URL issues, but am now getting the following error:
Dynamic SQL Error; SQL error code = -104; Unexpected end of command - line 1, column 8 [SQLState:42000, ISC error code:335544851]
With the highlighted error line being:
at com.inductiveautomation.ignition.gateway.datasource.DelegatingStatement.executeQuery(DelegatingStatement.java:64)
We were able to get Firebird working with these settings on the translator and driver, big thank you to John Saunders from Inductive Automation for helping out.
Translator
Create Table Syntax: CREATE TABLE {tablename} ({creationdef}{primarykeydef})
Create Sequence Syntax: CREATE GENERATOR {tablename}_ID
Create Trigger Syntax: CREATE TRIGGER {tablename}_trigger FOR {tablename}
Create Index Syntax: CREATE INDEX {indexname} ON {tablename}({columnname})
Auto Increment Field Definition: {type} NOT NULL AUTO_INCREMENT
Alter Table Syntax: ALTER TABLE {tablename} {alterdef}
Add Column Syntax: ADD COLUMN {columnname} {type}
Primary Key Syntax: PRIMARY KEY ({columnname})
Limit Syntax: LIMIT {limit}
Limit Position: Front
Current Timestamp Query: SELECT CURRENT_TIMESTAMP FROM rdb$database
Column Quote Character: “
Fetch Key Query: SELECT max{{columnname}} FROM {tablename}
Driver
Classname: org.firebirdsql.jdbc.FBDriver
JAR file: jaybird-6.0.3.jar or equivalent
Driver Type: Firebird
URL format: jdbc:firebirdsql:10.1.1.1[/port]:/path/to/db.fdb
Default Validation Query: SELECT 1 FROM rdb$database
Default Translator: FIREBIRD
