This is the error block in total from the log.
com.inductiveautomation.ignition.common.script.JythonExecException: Traceback (most recent call last): File "", line 20, in valueChanged at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:362) at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:258) at sun.reflect.GeneratedMethodAccessor134.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) java.lang.Exception: java.lang.Exception: Error executing system.db.runPrepUpdate(INSERT INTO AUDIT_EVENTS_TagChanges (EVENT_TIMESTAMP,ACTOR,ACTOR_HOST,ACTION,ACTION_TARGET,ACTION_VALUE,STATUS_CODE,ORIGINATING_SYSTEM,ORIGINATING_CONTEXT) VALUES (?,?,?,?,?,?,?,?,?), [current_timestamp, BOB BUILDER, HOSTNAME, Part Code Changed, [default]CoreCert/Station 1/Part Code, TEST, 0, TEST, 4], CoreCert_DB, , false, false)
at org.python.core.Py.JavaError(Py.java:495)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:186)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:431)
at org.python.core.PyObject.__call__(PyObject.java:320)
at org.python.pycode._pyx15.valueChanged$1(:20)
at org.python.pycode._pyx15.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.PyBaseCode.call(PyBaseCode.java:301)
at org.python.core.PyFunction.function___call__(PyFunction.java:376)
at org.python.core.PyFunction.__call__(PyFunction.java:371)
at org.python.core.PyFunction.__call__(PyFunction.java:361)
at org.python.core.PyFunction.__call__(PyFunction.java:356)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:649)
at com.inductiveautomation.ignition.common.sqltags.scripts.TagScriptManager$FunctionInvokerImpl.run(TagScriptManager.java:493)
at com.inductiveautomation.ignition.common.sqltags.scripts.AbstractTagScript.invoke(AbstractTagScript.java:33)
at com.inductiveautomation.ignition.common.sqltags.scripts.TagScriptManager$Task.invoke(TagScriptManager.java:442)
at com.inductiveautomation.ignition.common.sqltags.scripts.TagScriptManager$TagScriptDispatcher.run(TagScriptManager.java:405)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:518)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: org.python.core.PyException: Traceback (most recent call last): File "", line 20, in valueChanged at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:362) at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:258) at sun.reflect.GeneratedMethodAccessor134.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) java.lang.Exception: java.lang.Exception: Error executing system.db.runPrepUpdate(INSERT INTO AUDIT_EVENTS_TagChanges (EVENT_TIMESTAMP,ACTOR,ACTOR_HOST,ACTION,ACTION_TARGET,ACTION_VALUE,STATUS_CODE,ORIGINATING_SYSTEM,ORIGINATING_CONTEXT) VALUES (?,?,?,?,?,?,?,?,?), [current_timestamp, BOB BUILDER, HOSTNAME, Part Code Changed, [default]CoreCert/Station 1/Part Code, TEST, 0, TEST, 4], CoreCert_DB, , false, false)
... 30 common frames omitted
Caused by: java.lang.Exception: Error executing system.db.runPrepUpdate(INSERT INTO AUDIT_EVENTS_TagChanges (EVENT_TIMESTAMP,ACTOR,ACTOR_HOST,ACTION,ACTION_TARGET,ACTION_VALUE,STATUS_CODE,ORIGINATING_SYSTEM,ORIGINATING_CONTEXT) VALUES (?,?,?,?,?,?,?,?,?), [current_timestamp, BOB BUILDER, HOSTNAME, Part Code Changed, [default]CoreCert/Station 1/Part Code, TEST, 0, TEST, 4], CoreCert_DB, , false, false)
... 29 common frames omitted
Caused by: java.sql.SQLException: Datasource "CoreCert_DB" does not exist in this Gateway.
at com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl.getConnection(DatasourceManagerImpl.java:139)
at com.inductiveautomation.ignition.gateway.script.GatewayDBUtilities.getConnection(GatewayDBUtilities.java:88)
at com.inductiveautomation.ignition.gateway.script.GatewayDBUtilities.getConnection(GatewayDBUtilities.java:73)
at com.inductiveautomation.ignition.gateway.script.GatewayDBUtilities._runPrepStmt(GatewayDBUtilities.java:127)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:256)
... 27 common frames omitted
I have also tried NamedQueries as well with no luck (the test function works in the namedquery builder, but the query doesn’t insert anything when triggered from the tag change, it doesn’t even leave an error log in my case (probably a whole seperate issue). I’m going to attempt the following test to simplify things
- Create a simple table named testTable (Id, inputstring, inputint, inputfloat)
- Create a NamedQuery to call an insert on that table
- Trigger that NamedQuery from a tag changed event
