I have two types of binding and control a valve.
One : Direct bind Tag
Audit Events can log the tag write .
Two: Click Script write Tag
Audit Events can't log the tag write .
How to resolve the Two question?
Maybe use system.util.audit to manually log the write to the audit db.
Looks like everything is set up normally, should be able to just use the function.
system.tag.write is deprecated and kept around for backwards compatibility. (For updating from V7.x to 8.x) You should only use system.tag.writeBlocking, even with single tag writes. I bet the older function is missing something that ties it into the audit system but IA would have to confirm.
Perspective scripts run on the gateway. Did you set the Audit profile there?
Security -> General -> Gateway Audit Profile
EDIT: nvm, I don't think that captures it.
