Can you add a value for the action_value (success/failure) for login events in the Audit log. Currently you can’t tell the difference between login sucesses and login failures. I just happened to notice that one of the operators used a very strange user name to login with. After looking at the audit table I figured out by the status_code that it had to be a failure and that the operator entered their user name and password on the same line
Also, in the light of seeing the operator’s password and noticing it does not conform with the organization’s password rules, it would be helpful if the user management component had a way of enforcing some type of password security rules.
