Here i have enabled the audit profile.
the below image is my logs
Here i can't able to find the session login
did you enable the gateway audit profile on the gateway security settings and enable audit logging in the project properties on the Designer?
yes I did by referring[article] this (Audit Log and Profiles - Ignition User Manual 8.1 - Ignition Documentation) this
