Does somebody know why the actor is Unkown in the Audit Trails for Login/Logout actions. (Beside Logout Response).
Ignition 8.3.1
Identity Provider is Ignitition
I've seen this a lot as well in 8.1.47? Too
Do you know if this is working as expected? I did some tests with another fresh installed gateway (v8.1). It looks very similar, the only difference is that you also get the correct actor for a Login Response and not Unknown.
