Authenticate User Credentials but don't login or out in Perspective
I have a use case where I need to have an authorized person (supervisor) OK a step in a QC process (failing or reworking a part an operator has entered data for). What I would like to do is have a popup display (login style view) where the supervisor could enter their credentials (username & password) and then have a script authenticate the supervisor’s creds against the Active Directory User Source.
I see a number of functions that can check if a user has a certain role or security level, but unfortunately everything I have found either queries for the current logged in user or there is no password parameter passed to the function to actually authenticate.
Is there a way to provide for a security popup that takes username and password, then have that information passed to the user source to authenticate the credentials, and only return an “authenticated” status? I could get the rest of what I need as long as I know the entered credentials are good for the supervisor.
Thanks!
BTW, I don’t want to logout the logged in operator as that would require the part’s data to be re-entered before the supervisor could fail the part. Then it would require the operator to log back in to resume processing parts.
Thanks again! :smiley:
I think you could do something with system.security.validateUser.
It has a gateway scope, so if it doesn’t ‘just work’ you could use system.util.sendRequest to force the script to run in the gateway scope and return what you care about.
Hey zacht,
Thanks for the reply.
I had seen that method but discounted it (unreasonably) when I saw the first version of it having a Vision Scope. Since I’m working in Perspective I simply stopped looking at it when I saw that. Should have kept reading! :smiley:
I do appreciate the help!
I verified that this does work in Perspective.
