I am trying to redo some of my authentication and move it from an internal to a database setting. If my understanding is correct you can use multiple diffferent authentication profiles.
So in my Internal one I still have all the users currently assigned. Then I created a database using the auto create method. I placed my username and password in the there and assigned roles. When I did a test login it came back as fine.
The next thing I did was take the Internal profile and setup failover as SOFT and pointed it towards my new authenication profile. If I read the information correctly by doing this if the authentication does not find the user name and/or password in the first profile it will then go to the backup profile.
I then place a button on my screen for testing and placed the following code in it:
fpmi.security.switchUser('mweaver','123456',event)
It keeps comming back as login failed. yet if I do it from the gateway authenication profile it works.
So what simple step did I miss?
