Dear Maam/Sir,
Is there a way to automatic clicked buttons when the tag value is true?
I have a scenario if the tag value is true, the button will auto clicked so that data will insert into the database. Thank you.
Please see attached:
Sample
Or other way, that if the trigger value is “true” automatically insert data into the database (PLC ID, Item Code, Item Description, Actual Weight, Farm source and Classification)
That is exactly what transaction groups are for. Part of the SQL Bridge module. Or you can script it with a tag change event.
Thanks for the info sir.
