Auto-grow and shrink Text Area component
I’m wondering if there is an easy way to get this sort of behavior: a Text Area component grows and shrinks past a basis as you type so that no scrollbar is shown. It looks like it’s a non-trivial task, even with access to the markup, but maybe one of you has an idea how to do this.
you can use resize i guess.
or track the size of the text through a script which adjusts the height(?)
edit: dont do this:
also there is a hacky way but kinda hard to use as it will need onkeydown events to track input… as it has no text property
you could also mimic a text area with a coordinatecontainer with some styling and give it these styles:
and set the height/width to auto. (and maybe a min-height/min-width)
you will need to change the style with a binding tho as ignition otherwise doesnt like the names starting with - like “-webkit”
(no guarantee it will work in the workstation tho)
you should probably also add in a max-height/width
-webkit-user-modify: read-write;
-moz-user-modify: read-write;
I will need to test this out later today! Even the HTML solution was hacky (using a div), so I’m sure if there is a solution, it’ll be a odd one.
