Automation Direct BRX Modbus TCP Timeout
I'm running a Gateway on version 8.1.44, connecting to an Automation Direct BRX DM1E-36 series PLC via Modbus TCP. I have ~1500 tags configured on 1000 and 5000 ms poll rates. The BRX is running firmware version 2.9.9.
The modbus server on the BRX is configured for a timeout of 60s with 8 allowed sessions. Ignition is configured for 2500ms timeout. The BRX average scan time is ~12ms with Ignition side response times of ~60ms.
Fairly consistently, Ignition's connection to the device will time out. Some times it takes 2, 3, 5, 6, or 8 hours for this to occur. I was able to get a wireshark capture from the vm during one of the time outs.
We have a second BRX D1ME-36 device that experiences similar dropouts but on a much longer timeline (12+hours or even days) that is running an almost identical setup but with only 15 tags on a 1000 ms poll rate.
Capture Overview Snippet
21	0.631707	IGN.addr	BRX.addr	Modbus/TCP	66	   Query: Trans: 13865; Unit:   0, Func:   4: Read Input Registers
22	0.642210	BRX.addr	IGN.addr	TCP	60	502 → 65343 [ACK] Seq=1345 Ack=73 Win=8180 Len=0
23	0.692383	BRX.addr	IGN.addr	Modbus/TCP	311	Response: Trans: 13865; Unit:   0, Func:   4: Read Input Registers
24	0.692547	IGN.addr	BRX.addr	Modbus/TCP	66	   Query: Trans: 13866; Unit:   0, Func:   2: Read Discrete Inputs
25	0.703593	BRX.addr	IGN.addr	TCP	60	502 → 65343 [ACK] Seq=1602 Ack=85 Win=8180 Len=0
26	0.750362	BRX.addr	IGN.addr	Modbus/TCP	91	Response: Trans: 13866; Unit:   0, Func:   2: Read Discrete Inputs
27	0.750549	IGN.addr	BRX.addr	Modbus/TCP	66	   Query: Trans: 13867; Unit:   0, Func:   3: Read Holding Registers
28	0.762763	BRX.addr	IGN.addr	TCP	60	502 → 65343 [ACK] Seq=1639 Ack=97 Win=8180 Len=0
29	0.811725	BRX.addr	IGN.addr	Modbus/TCP	155	Response: Trans: 13867; Unit:   0, Func:   3: Read Holding Registers
30	0.811832	IGN.addr	BRX.addr	Modbus/TCP	66	   Query: Trans: 13868; Unit:   0, Func:   3: Read Holding Registers
31	0.822298	BRX.addr	IGN.addr	TCP	60	502 → 65343 [ACK] Seq=1740 Ack=109 Win=8180 Len=0
32	4.292852	IGN.addr	BRX.addr	Modbus/TCP	66	   Query: Trans: 13869; Unit:   0, Func:   1: Read Coils
33	4.298118	BRX.addr	IGN.addr	TCP	60	[TCP Previous segment not captured] 502 → 65343 [ACK] Seq=1997 Ack=121 Win=8180 Len=0
34	7.296778	IGN.addr	BRX.addr	Modbus/TCP	66	   Query: Trans: 13870; Unit:   0, Func:   3: Read Holding Registers
35	7.301364	BRX.addr	IGN.addr	TCP	60	502 → 65343 [ACK] Seq=1997 Ack=133 Win=8168 Len=0
36	10.300639	IGN.addr	BRX.addr	Modbus/TCP	66	   Query: Trans: 13871; Unit:   0, Func:   4: Read Input Registers
37	10.306736	BRX.addr	IGN.addr	TCP	60	502 → 65343 [ACK] Seq=1997 Ack=145 Win=8156 Len=0
38	13.305799	IGN.addr	BRX.addr	TCP	54	65343 → 502 [FIN, ACK] Seq=145 Ack=1740 Win=63020 Len=0
39	13.307861	IGN.addr	BRX.addr	TCP	66	58309 → 502 [SYN, ECE, CWR] Seq=0 Win=64240 Len=0 MSS=1460 WS=256 SACK_PERM
40	13.308506	BRX.addr	IGN.addr	TCP	60	502 → 65343 [ACK] Seq=1997 Ack=146 Win=8156 Len=0
41	13.309119	BRX.addr	IGN.addr	TCP	60	502 → 58309 [SYN, ACK] Seq=0 Ack=1 Win=8192 Len=0 MSS=1458
42	13.309145	IGN.addr	BRX.addr	TCP	54	58309 → 502 [ACK] Seq=1 Ack=1 Win=64240 Len=0
43	15.572253	IGN.addr	BRX.addr	Modbus/TCP	66	   Query: Trans: 13872; Unit:   0, Func:   4: Read Input Registers
44	15.574175	BRX.addr	IGN.addr	TCP	60	502 → 58309 [ACK] Seq=1 Ack=13 Win=8180 Len=0
45	15.610644	BRX.addr	IGN.addr	Modbus/TCP	311	Response: Trans: 13872; Unit:   0, Func:   4: Read Input Registers
46	15.610839	IGN.addr	BRX.addr	Modbus/TCP	66	   Query: Trans: 13873; Unit:   0, Func:   3: Read Holding Registers
47	15.621816	BRX.addr	IGN.addr	TCP	60	502 → 58309 [ACK] Seq=258 Ack=25 Win=8180 Len=0
48	15.669334	BRX.addr	IGN.addr	Modbus/TCP	243	Response: Trans: 13873; Unit:   0, Func:   3: Read Holding Registers
49	15.669499	IGN.addr	BRX.addr	Modbus/TCP	66	   Query: Trans: 13874; Unit:   0, Func:   3: Read Holding Registers
50	15.680483	BRX.addr	IGN.addr	TCP	60	502 → 58309 [ACK] Seq=447 Ack=37 Win=8180 Len=0
51	15.728451	BRX.addr	IGN.addr	Modbus/TCP	311	Response: Trans: 13874; Unit:   0, Func:   3: Read Holding Registers
52	15.728629	IGN.addr	BRX.addr	Modbus/TCP	66	   Query: Trans: 13875; Unit:   0, Func:   3: Read Holding Registers
53	15.739494	BRX.addr	IGN.addr	TCP	60	502 → 58309 [ACK] Seq=704 Ack=49 Win=8180 Len=0
Wrapper.log snippet
INFO   | jvm 2    | 2025/05/01 15:35:27 | W [d.M.B.B.TimeoutDaemon         ] [15:35:27.244]: ScheduledRequest[com.inductiveautomation.xopc.drivers.modbus2.requests.ReadHoldingRegistersRequest@5192a815] request with key "13868" failed due to timeout. device-name=  BRX
INFO   | jvm 2    | 2025/05/01 15:35:27 | W [d.M.ReadHoldingRegistersRequest] [15:35:27.244]: Request failed. FailureType==TIMEOUT device-name=  BRX
INFO   | jvm 2    | 2025/05/01 15:35:27 | java.lang.Exception: Request failed by TimeoutDaemon due to timeout: ScheduledRequest[com.inductiveautomation.xopc.drivers.modbus2.requests.ReadHoldingRegistersRequest@5192a815]
INFO   | jvm 2    | 2025/05/01 15:35:27 | 	at com.inductiveautomation.xopc.driver.api.BasicRequestCycle$TimeoutDaemon.failRequests(BasicRequestCycle.java:376)
INFO   | jvm 2    | 2025/05/01 15:35:27 | 	at com.inductiveautomation.xopc.driver.api.BasicRequestCycle$TimeoutDaemon.run(BasicRequestCycle.java:328)
INFO   | jvm 2    | 2025/05/01 15:35:27 | 	at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
INFO   | jvm 2    | 2025/05/01 15:35:27 | 	at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source)
INFO   | jvm 2    | 2025/05/01 15:35:27 | 	at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
INFO   | jvm 2    | 2025/05/01 15:35:27 | 	at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO   | jvm 2    | 2025/05/01 15:35:27 | 	at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO   | jvm 2    | 2025/05/01 15:35:27 | 	at java.base/java.lang.Thread.run(Unknown Source)
DEBUG  | wrapperp | 2025/05/01 15:35:29 | Send a packet PING : ping 01db5781
INFO   | jvm 2    | 2025/05/01 15:35:29 | WrapperManager Debug: Received a packet PING : ping 01db5781
INFO   | jvm 2    | 2025/05/01 15:35:29 | WrapperManager Debug: Send a packet PING : ping 01db5781
DEBUG  | wrapperp | 2025/05/01 15:35:29 | read a packet PING : ping 01db5781
INFO   | jvm 2    | 2025/05/01 15:35:30 | W [d.M.B.B.TimeoutDaemon         ] [15:35:30.248]: ScheduledRequest[com.inductiveautomation.xopc.drivers.modbus2.requests.ReadCoilsRequest@2b22cca5] request with key "13869" failed due to timeout. device-name=  BRX
INFO   | jvm 2    | 2025/05/01 15:35:30 | W [d.M.ReadCoilsRequest          ] [15:35:30.248]: Request failed. FailureType==TIMEOUT device-name=  BRX
INFO   | jvm 2    | 2025/05/01 15:35:30 | java.lang.Exception: Request failed by TimeoutDaemon due to timeout: ScheduledRequest[com.inductiveautomation.xopc.drivers.modbus2.requests.ReadCoilsRequest@2b22cca5]
INFO   | jvm 2    | 2025/05/01 15:35:30 | 	at com.inductiveautomation.xopc.driver.api.BasicRequestCycle$TimeoutDaemon.failRequests(BasicRequestCycle.java:376)
INFO   | jvm 2    | 2025/05/01 15:35:30 | 	at com.inductiveautomation.xopc.driver.api.BasicRequestCycle$TimeoutDaemon.run(BasicRequestCycle.java:328)
INFO   | jvm 2    | 2025/05/01 15:35:30 | 	at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
INFO   | jvm 2    | 2025/05/01 15:35:30 | 	at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source)
INFO   | jvm 2    | 2025/05/01 15:35:30 | 	at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
INFO   | jvm 2    | 2025/05/01 15:35:30 | 	at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO   | jvm 2    | 2025/05/01 15:35:30 | 	at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO   | jvm 2    | 2025/05/01 15:35:30 | 	at java.base/java.lang.Thread.run(Unknown Source)
DEBUG  | wrapper  | 2025/05/01 15:35:32 |   SERVICE_CONTROL_INTERROGATE
DEBUG  | wrapperp | 2025/05/01 15:35:32 | Send a packet SERVICE_CONTROL_CODE : 4
INFO   | jvm 2    | 2025/05/01 15:35:32 | WrapperManager Debug: Received a packet SERVICE_CONTROL_CODE : 4
INFO   | jvm 2    | 2025/05/01 15:35:32 | WrapperManager Debug: ServiceControlCode from Wrapper with code 4
INFO   | jvm 2    | 2025/05/01 15:35:33 | W [d.M.B.B.TimeoutDaemon         ] [15:35:33.252]: ScheduledRequest[com.inductiveautomation.xopc.drivers.modbus2.requests.ReadHoldingRegistersRequest@25e21faf] request with key "13870" failed due to timeout. device-name=  BRX
INFO   | jvm 2    | 2025/05/01 15:35:33 | W [d.M.ReadHoldingRegistersRequest] [15:35:33.252]: Request failed. FailureType==TIMEOUT device-name=  BRX
INFO   | jvm 2    | 2025/05/01 15:35:33 | java.lang.Exception: Request failed by TimeoutDaemon due to timeout: ScheduledRequest[com.inductiveautomation.xopc.drivers.modbus2.requests.ReadHoldingRegistersRequest@25e21faf]
INFO   | jvm 2    | 2025/05/01 15:35:33 | 	at com.inductiveautomation.xopc.driver.api.BasicRequestCycle$TimeoutDaemon.failRequests(BasicRequestCycle.java:376)
INFO   | jvm 2    | 2025/05/01 15:35:33 | 	at com.inductiveautomation.xopc.driver.api.BasicRequestCycle$TimeoutDaemon.run(BasicRequestCycle.java:328)
INFO   | jvm 2    | 2025/05/01 15:35:33 | 	at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
INFO   | jvm 2    | 2025/05/01 15:35:33 | 	at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source)
INFO   | jvm 2    | 2025/05/01 15:35:33 | 	at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
INFO   | jvm 2    | 2025/05/01 15:35:33 | 	at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO   | jvm 2    | 2025/05/01 15:35:33 | 	at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO   | jvm 2    | 2025/05/01 15:35:33 | 	at java.base/java.lang.Thread.run(Unknown Source)
DEBUG  | wrapperp | 2025/05/01 15:35:34 | Send a packet PING : ping 01db57b3
INFO   | jvm 2    | 2025/05/01 15:35:34 | WrapperManager Debug: Received a packet PING : ping 01db57b3
INFO   | jvm 2    | 2025/05/01 15:35:34 | WrapperManager Debug: Send a packet PING : ping 01db57b3
DEBUG  | wrapperp | 2025/05/01 15:35:34 | read a packet PING : ping 01db57b3
INFO   | jvm 2    | 2025/05/01 15:35:36 | W [d.M.B.B.TimeoutDaemon         ] [15:35:36.257]: ScheduledRequest[com.inductiveautomation.xopc.drivers.modbus2.requests.ReadInputRegistersRequest@29b6f4c1] request with key "13871" failed due to timeout. device-name=  BRX
INFO   | jvm 2    | 2025/05/01 15:35:36 | W [d.M.ReadInputRegistersRequest ] [15:35:36.257]: Request failed. FailureType==TIMEOUT device-name=  BRX
INFO   | jvm 2    | 2025/05/01 15:35:36 | java.lang.Exception: Request failed by TimeoutDaemon due to timeout: ScheduledRequest[com.inductiveautomation.xopc.drivers.modbus2.requests.ReadInputRegistersRequest@29b6f4c1]
INFO   | jvm 2    | 2025/05/01 15:35:36 | 	at com.inductiveautomation.xopc.driver.api.BasicRequestCycle$TimeoutDaemon.failRequests(BasicRequestCycle.java:376)
INFO   | jvm 2    | 2025/05/01 15:35:36 | 	at com.inductiveautomation.xopc.driver.api.BasicRequestCycle$TimeoutDaemon.run(BasicRequestCycle.java:328)
INFO   | jvm 2    | 2025/05/01 15:35:36 | 	at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
INFO   | jvm 2    | 2025/05/01 15:35:36 | 	at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source)
INFO   | jvm 2    | 2025/05/01 15:35:36 | 	at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
INFO   | jvm 2    | 2025/05/01 15:35:36 | 	at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO   | jvm 2    | 2025/05/01 15:35:36 | 	at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO   | jvm 2    | 2025/05/01 15:35:36 | 	at java.base/java.lang.Thread.run(Unknown Source)
What is strange is that for the requests that time out, the BRX sends a TCP ACK to the modbus poll request as normal, but then never seems to send the Modbus TCP response after the ack, compared to the normal Modbus Query -> TCP Ack-> Modbus Response format that I see during the normal communications. (Which you can also see leading up to the disconnect in the snippet)
Following the connection reset sent from Ignition the device begins transmitting normally.
From what I can tell this doesn't appear to be an Ignition specifc issue, its either the BRX side or something in between, but I don't know what to look at/for at this time. The BRX logs don't show any errors or warnings regarding the modbus server. Any pointers would be appreciated.
Have you looked at the device overload stat on the gateway?
Device hovers at 1-4% on either scan group, save for on reconnect, where I've seen it jump as high as 60%. That's probably from Ignition trying to get all the tags at once. These PLCs don't seem to like going over 1500 tags.
If I'm not mistaken, 1-4% means 101-104% total load. 60% would mean the device is at 160% total load and would likely be the timeout culprit.
Yup, broken BRX firmware. Complain to them.
Following up on this, we bumped the firmware revision to 2.10.3, and we have yet to see a disconnect after running for over a week. We are continuing to monitor this along with some other items that BRX support is having us watch.
