Automation Direct D-More Tags
Our PLC guy decided to try out an Automation Direct Do-More. We have device successfully connected using Modbus TCP driver. Does anyone have an example on how to map out the tags so we can work with them in designer? Everything else we have is Allen Bradley, so we have yet to do one of these.
I am probably way too late to help you, but I am doing my first project with Automation DIrect PLC communication. I downloaded a csv file “template” found at the very bottom of this page:
https://inductiveautomation.com/downloads/extra-material
I followed the guidance in the Ignition Help for Modbus Mapping to add that mapping template to my Device configuration. There was an error when I tried to save it. My version of Ignition didn’t like the “C” prefix in the template for coils, so I changed it to “CR” and it took it.
Next, I have User Data Types with parameters that I needed to use with the addressing scheme made possible with the device mapping. So I made a new tag and browsed the OPC server to pick an address so that I could view how it ended up looking:
ns=1;s=[MAIN]1.Vbcd1400
(my device is named “MAIN”).
So I took that format and pasted part of it into my UDT tag using my parameter {Base} where Base is an integer representing the “Base” address of each UDT structure in use.
To expand further on this example, I have 7 wells each with 8 integers holding bits and integers from each well. The flow rate is the 4th item. My UDT is set up with FlowRate as a tag within it addressed to ns=1;s=[MAIN]1.Vbcd{Base+4}
A tag of Type “Well” named Well_1 has its parameter “Base” set to 6100, so when i drill into it and find FlowRate, its OPC item path is ns=1;s=[MAIN]1.Vbcd6104
I can’t test all of this until I can install the application on site and connect to their PLC, but if something is not right, by using the addressing template and UDT structures, I should only have to make adjustments in a very few places to correct the addressing of the whole application.
Okie,
Those templates are for the DL240 and DL250 processors. He was talking about a Do-More processor.
For the Do-More processors (and the BRX line), the native registers will need to be specifically mapped to Modbus registers inside the ladder program. This was a specific design decision by Host to limit access to the memory registers in this way.
Just thought I’d point that out for others finding this post.
Brian
We are actually doing a DL250 now as well. Your post was very helpful, Thanks!
Hey there Brian, not sure if you or anyone will reply but eitherway. I'm trying to do something similar here and have 3 numbers I copied over to the Modbus Holding Registers inside of the Do-More rung program. Is there anything else that I have to do in order to have these 3 numbers visible in Ignition?
Hi Marcos, welcome!
Sorry, I don't check the forums as much as I used to..
On a high level, assuming you are connected over ethernet to the BRX, you will need to have the appropriate IP addressing between the BRX and Ignition server (verify with ping), activate the Modbus server in the BRX software (link to manual below), create a device in Ignition to connect to the BRX (pretty simple, there's probably instructions somewhere on the forum), and then create a tag that is pointing at that Ignition device, with one of the addresses you want to see. I don't remember if you need to mess with the Ignition device settings. I seem to remember changing the word order from the default for floats and long ints, but it's been a bit and I don't have a setup handy that I can check.
I'm guessing you figured all this out already, but I figured I'd reply anyway. Better late than never, I guess :slight_smile:
Good luck with Ignition!
Good News !! BRX just came out with a OPC UA POM adapter 189.00 Plug it into a BRX PLC and you now have a server serving up the BRX tag data base.
It’s only weeks old so I’m not finding examples of it working yet though.:crossed_fingers:
A little more information on the BRX OPC-UA Server, it is limited to "500 of the CPU's I/O and memory locations".
Sigh...
Maybe applications where you're using a BRX don't commonly have many more variables than this... or maybe hardware vendors just continue to be out of touch...
We are routinely hitting ~2000 tags on modbus with our BRX's, and it seems to be the upper limit with these(at least based on comms overload), without moving to longer poll rates. They definitely do not have a lot of horse power, so I'm wondering if the small OPC limit is due to that.
I wonder if they would be able to get a larger limit if the OPC module had its own processor for comms, but the modules are so small I don't think it would fit. I personally wouldn't mind a full sized module if it gave me 2000 tags of OPC.
The value change detection for subscriptions needed to implement OPC or MQTT protocols is a significant burden on modest PLC hardware, both in memory and CPU cycles, and risk to the PLC's realtime guarantees. Conventional computing platforms will remain better at this than PLCs for the foreseeable future.
I don't see the performance of OPC or MQTT in PLC hardware ever matching simpler protocols.
Yeah, but in this case they built it as an add-on... all the burden of the change detection can happen in the add-on CPU/memory, which should have been chosen more thoughtfully.
Ah, I missed that nuance.
