Maybe there is an issue still with nested forEach() expressions? As I was attempting to simplify one of my expressions that was previously using objectScript to do some iterations, and I ran into this. I worked up a simple example that shows what I am seeing.
Working Expression:
unionAll(
asMap('Col1','i','Col2','i','Col3','i'),
asList(
asList(0,1,2),
forEach(
asList(3,4,5),
it()
Non-Working Expression:
unionAll(
asList(
asList(0,1,2),
forEach(
asList(3,4,5),
forEach(
asList(1),
it(1)
)[0]
The two expressions should produce the same dataset, unless my understanding is flawed, which is quite possible. The second one however results in the following error.
Error
10:03:15.144 [AWT-EventQueue-0] ERROR com.inductiveautomation.ignition.client.util.gui.ErrorUtil - null
java.lang.Exception: Error executing expression binding on
Stop Occurances.Root Container.Table.data
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.runExpression(ExpressionPropertyAdapter.java:92)
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.startup(ExpressionPropertyAdapter.java:113)
at com.inductiveautomation.factorypmi.application.binding.DefaultInteractionController.setPropertyAdapter(DefaultInteractionController.java:219)
at com.inductiveautomation.factorypmi.designer.property.configurators.ExpressionConfigurator.bind(ExpressionConfigurator.java:246)
at com.inductiveautomation.factorypmi.designer.property.configurators.ExpressionConfigurator.tryCommit(ExpressionConfigurator.java:192)
at com.inductiveautomation.factorypmi.designer.property.configurators.ConfiguratorMultiplexor$EditorParent.tryCommit(ConfiguratorMultiplexor.java:398)
at com.inductiveautomation.factorypmi.designer.property.configurators.ConfiguratorMultiplexor.tryCommit(ConfiguratorMultiplexor.java:546)
at com.inductiveautomation.factorypmi.designer.property.configurators.DynamicOptsDialog.doOK(DynamicOptsDialog.java:95)
at com.inductiveautomation.factorypmi.designer.property.configurators.DynamicOptsDialog$1.actionPerformed(DynamicOptsDialog.java:64)
at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
at java.desktop/java.awt.WaitDispatchSupport$2.run(Unknown Source)
at java.desktop/java.awt.WaitDispatchSupport$4.run(Unknown Source)
at java.desktop/java.awt.WaitDispatchSupport.enter(Unknown Source)
at java.desktop/java.awt.Dialog.show(Unknown Source)
at java.desktop/java.awt.Component.show(Unknown Source)
at java.desktop/java.awt.Component.setVisible(Unknown Source)
at java.desktop/java.awt.Window.setVisible(Unknown Source)
at java.desktop/java.awt.Dialog.setVisible(Unknown Source)
at com.inductiveautomation.factorypmi.designer.property.configurators.DynamicOptsDialog.showDialog(DynamicOptsDialog.java:163)
at com.inductiveautomation.factorypmi.designer.model.VisionDesignerImpl.openBindingDialog(VisionDesignerImpl.java:1169)
at com.inductiveautomation.factorypmi.designer.property.editors.bb.DynamicOptionsButton.actionPerformed(DynamicOptionsButton.java:37)
at com.jidesoft.plaf.basic.BasicJideButtonListener.mouseReleased(Unknown Source)
at java.desktop/java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicTableUI$Handler.repostEvent(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicTableUI$Handler.mouseReleased(Unknown Source)
at com.jidesoft.swing.DelegateMouseInputListener.mouseReleased(Unknown Source)
Caused by: java.lang.ClassCastException: class com.inductiveautomation.ignition.client.expressions.ClientDynamicDispatchFunction cannot be cast to class com.automation_pros.simaids.expressions.SimpleIterator (com.inductiveautomation.ignition.client.expressions.ClientDynamicDispatchFunction and com.automation_pros.simaids.expressions.SimpleIterator are in unnamed module of loader java.net.URLClassLoader @2c7ad468)
at com.automation_pros.simaids.expressions.IterationHelper.anyIterationFunction(IterationHelper.java:308)
at com.automation_pros.simaids.expressions.IterationHelper.condSubstExpression(IterationHelper.java:224)
at com.automation_pros.simaids.expressions.IterationHelper.preExecuteAll(IterationHelper.java:154)
at com.automation_pros.simaids.expressions.SimpleIterator.execute(SimpleIterator.java:202)
at com.inductiveautomation.ignition.client.expressions.ClientDynamicDispatchFunction.execute(ClientDynamicDispatchFunction.java:43)
at com.inductiveautomation.ignition.common.expressions.FunctionExpression.execute(FunctionExpression.java:69)
at com.inductiveautomation.ignition.common.expressions.functions.BaseFunction.executeAll(BaseFunction.java:64)
at com.automation_pros.simaids.expressions.AsList.execute(AsList.java:39)
at com.automation_pros.simaids.expressions.UnionAll.execute(UnionAll.java:52)
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.runExpression(ExpressionPropertyAdapter.java:83)
... 102 common frames omitted
I am trying to replicate the following comprehension which sums the counts by shift on data shaped similar to what I provided above (same columnCount).
[sum([args[0].getValueAt(r,c + 8 * s) for r in xrange(args[0].rowCount) for c in xrange(1,9)]) for s in xrange(3) for _ in (xrange(8))]
As ugly as that may or may not be, it works.
