Automation Professionals is pleased to announce the availability of several of its 3rd party modules as BETAs for the v8.3 beta, hosted here:
https://www.automation-pros.com/ign83/
The following modules are currently available:
- EtherNet/IP Class1 Communications Suite
- Advanced Modbus Driver
- Image and Video Streaming Driver
- Integration Toolkit
- Blob Server
- NoteChart
Known Issues:
- All modules are currently incompatible with v8.3 module update procedure, apparently due to my module file names including version and build information. You must uninstall any module to be updated, restart, then install the new version.
- No gateway WebUI has been implemented yet for any of these. Migration via v8.1 gateway backup restoration into v8.3 is the simplest way to configure the drivers that need a complex configuration.
- If not migrating, edit/place a config file in
.../data/config/resources/core/com.inductiveautomation.opcua/device/{devName}/. File name must beConfig.xmlfor EtherNet/IP Host devices, andnodes.csvfor Modbus devices. Use the same formats as used in v8.1 import/export.
This post will be updated as more modules are released and issues resolved.
Edit 2025-08-01: Updated EtherNet/IP driver with some designer RPC fixes, so the designer tools for tag/type/code/assembly/scanner editing work. (Missing Protobuf types, mostly.)
Edit 2025-09-29: Updated EtherNet/IP driver with bugfixes from latest v8.1 beta. Verified all module compilation against v8.3.0 release. Image Streamer, Integration Toolkit, and Blob Server are now production grade--separate notices in their own topics to follow.
Edit 2025-11-17: Updated EtherNet/IP driver with new React Configuration UI. The config import functions perform syntax verification in all cases. I have some 8.1 to 8.3 migration QA to redo, but this beta may be declared a release candidate later this week.
Edit 2025-12-18: Added a beta of my NoteChart Module. Only passed light QA so far.
