Hello,
I am having problems logging into avaya ip office from VOIP Voice Notification.
Getting error unknown[1]
When I check the logs in Avaya, it says that the user/password is wrong.
I have entered the correct user/password.
(2187/******)
Anyone else had the same problem with Avaya?
I found a guide from 2013 on this forum, and I followed the guide with no luck.
This is the setup in avaya:
I have connection if i use (blank) no password.
even that i have a password setup in avaya.
I have tested the pipline but no call on the phone.
I got this in the log:
CallManager 24Mar2023 10:19:59 Call has exceeded its permitted lifespan, cancelling.
| PhoneCall |
24Mar2023 10:19:59 |
Error executing call 'hidden adress for forum' |
| java.lang.NullPointerException: null |
| at net.sourceforge.peers.sip.Utils.getTopVia(Utils.java:39) |
| at net.sourceforge.peers.sip.transaction.TransactionManager.getClientTransaction(TransactionManager.java:119) |
| at net.sourceforge.peers.sip.core.useragent.UAC.terminate(UAC.java:201) |
| at com.inductiveautomation.alarming.notification.sip.call.CallManager$PhoneCall.closeCall(CallManager.java:443) |
| at com.inductiveautomation.alarming.notification.sip.call.CallManager$PhoneCall.run(CallManager.java:339) |
You probably should open a support ticket.
