I have many number of entries or records of data in a day I just wanted to show the average of value for a particular day on timeseries chart in perspective ignition.
I am not able to show the average value for a particular day.
Should we create a code for the same.
If your data is coming from a SQL query then you should use the SQL AVG() function to return the data in the format required.
I have used the SQL Avg function it is returning all the average data I just needed the specific one day data to show as selected.
Please show your SQL query.
Use the </> code formatting button to preserve code indentation and apply syntax highlighting.
Hi-
You might consider grouping by the date:
SELECT
AVG(myValue) AS avgValue,
CAST(myDateTime AS DATE) AS dateOnly
FROM myTable
GROUP BY CAST(myDateTime AS DATE)
This would give you the average value for each date in the table.
Or if you need a specific date:
SELECT
FROM myTable
WHERE CAST(myDateTime AS DATE) = '2022-01-01'
It would probably be best to parameterize the date value with a binding.
HTH.
-Shane
