Hi
I need a little help
I am trying to create an OPC connection between Phoenix contact PLC – which has an OPC server (called AX-OPC server). The spec on it are OPC-DA 1.0a and OPC-DA2.05 with projid= Phoenix.contact.AX-server.21
In ignition, where one creates an OPC server connection using OPC-DA COM, its supports OPC-DA version 2 and 3
will this connection work? as the status of the connection its saying connecting and not connected!
any help???
