I am trying to display video from a Axis M3066-V. in the IP camera Component.
I’m using version 7.9.4
I currently have the URL Property set to this -
http://10.0.0.161/axis-cgi/mjpg/video.cgi?
User Authentication Property is set properly.
This URL works great from any web browser but I am still getting the “IOException: Max Buffer Size Reached” Error.
I have been on the phone with Axis and this is the best we could come up with.
Any help is greatly appreciated.
Here’s a screen shot of an old setup that I used.
What’s your buffer size set to?
Also, have you tried reducing the image quality by specifying it in the url (VAPIX)? Obviously not a fix but a just a check to see if you can get any content showing at any frame rate/resolution.
My current value for the Property Camera Buffer Size is default of 512,000.
The camera’s resolution was set to 2304x1728 (4:3)
I did as you recommended and changed it to 1920x1080 (16:9) and the image was displayed.
Thank you for your help, this appears to be working.
PS - I would like to note that the image was properly displayed at all the following Camera resolution settings.
1280 x 960 (4:3)
1024 x 768 (4:3)
800 x 600 (4:4)
640 x 480 (4:3)
320 x 240 (4:3)
1920 x 1080 (16:9)
1280 x 720 (16:9)
1024 x 576 (16:9)
640 x 360 (16:9)
