Azure Injector Settings
I’ve been trying to connect Ignition to Azure IoT Hub. I’ve followed the documentation described in [Cirius Link](Getting Started: Azure Injector Quick Start - MQTT Modules for Ignition 7.x - Confluence)
and still i’m finding that the in Azure Injector Settings, the status shows “DISCONNECTED”.
(Attaching a screenshot for ref)
Request to please help since i’ve no idea what the issue is on. Since its not throwing any errors anywhere.
Hi did you find your way around it
Not sure if this is the issue you're facing but, make sure in the password area here
You enter the device Connection String- Primary Key
