Azure Load Balancer with Ignition Cloud Edition and IDP
Reaching out to the forum to see if anyone has experience with configuring an Azure Load Balancer with Ignition Cloud Edition and IDP. I have reviewed the AWS Ignition KB (Application Load Balancers and Ignition), but there are (from what I can tell) some differences in the Azure environment.
The pseudo process I am hoping for is:
  1. Client goes to URL --> Load Balancer (End point somewhere.com)
  2. Load Balance (LB) --> IDP (LB redirects Client to IDP for authentication)
  3. IDP --> LB (IDP authenticates user and pass token to LB)
  4. LB --> Ignition Gateway (Load balancer pass user token to Gateway with a 'sticky' session connection.)
  5. Ignition Gateway (IGW) --> LB --> Client (Perspective page received by user)
Any experience out there that I can draw upon?
I think you'll want to actually configure Ignition with an [Identity Provider}(Configuring Identity Providers | Ignition User Manual) configuration instead of having the Azure LB inject the auth. A few reasons why include:
  • With the proposed configuration, you won't be able to launch the Designer (it doesn't yet tolerate that kind of injected auth flow) against the gateway. You'd need a separate path.
  • While you could use this method to "gate" access to a Perspective app, you won't be able to leverage any Ignition security features, as the user won't be logged into the app itself.
Thanks Kevin. Good insight.
