Hello everyone,
I am creating a reusable template in Ignition Vision for an analog input object.
The design uses a rectangle with rounded corners, but when I place the template on a Vision window, the template/root container appears behind the rounded rectangle. This creates a visible rectangular background around the rounded corners, even though the root container background is set to transparent and the border is set to No Border.
I have tried:
- Setting the template root background to transparent
- Setting the template instance background to transparent
- Setting the border to No Border
- Using both a Rectangle component and a Paintable Canvas
- Setting the root and canvas to non-opaque through scripting
However, the rectangular background around the rounded corners is still visible.
The template size is 140 × 64, and I would like to keep these dimensions without increasing the rounded rectangle beyond the template bounds.
Has anyone experienced this in Vision? Is there a proper way to make the template container fully transparent so that only the rounded object is visible?
Thanks.
Find the pictures below:
