I have a script that is pulling in a CSV file and dumping it into SQL every once in awhile (Project.FieldData.CSVtoSQL). I’m trying to run the script from the gateway for a number of reasons.
In the script I have a line that reads ‘inputFile=“M:\Vicon\SiteStatus - Current.csv”’
the script was written and tested running on the client side. After it was all working I added in a tag to call it via the Gateway Tag Change Script.
When I run it on the gateway machine it returns an error (via system console) ‘No such file or directory: “M:\Vicon\SiteStatus - Current.csv”’. Note the double backslashes. I tried changing the script just have the single backslash. The error message was exactly the same.
Calling the script from a Client Tag Change Script works fine. any suggestions on how to get the gateway script to work?
Thanks!
