BACnet Communication to Schneider SmartX AS-P Server
Hello there,
Does anyone has idea about Ignition BACnet communication with Schneider SmartX AS-P Server?
Have never used Ignition with BACnet before hence not getting how to achieve this and what data I would need from SmartX AS-P Server.
Please suggest.
Ignition Version: 8.1
Tried using BACnet/IP driver but not succeeded
What are the problems you are seeing with BACnet/IP?
My remote connection is Initialized, however I don’t see any Object Lists/tags under object list folder
Hi! Could you connect with SmartX AS-P Server?I have the same problem
I ended up connecting with Modbus protocol. Was not able to do so with BacNet
Thank you very much! Was it necessary to create a list of tags in SmartX Controler?
If using Modbus protocol then Yes
