Hi ,
I am configuring bacnet device on my Ignition gateway, and the staus becomes Uninitialized after it's initializing... for a few seconds.
I do the ping check , network seems fine.
I tried with other software to communicate with my bacnet device, it read data successfully.
Can someone help to understand where I did wrong when setup.
Here's some logs and screenshots of my configuration.
Ignition Logs:
| Logger | Time | Message |
| RequestUtils | 06Nov2023 11:25:21 | Chunked request failed. |
| RequestUtils | 06Nov2023 11:25:20 | Chunked request failed. |
| DefaultTransport | 06Nov2023 11:25:15 | Segment did not fit in segment window: segment=2, first=3, windowSize=1, key=Key(address=Address [networkNumber=13, macAddress=[1]], linkService=[c0,a8,1,e9,ba,c0], invokeId=54, fromServer=true) |
| DefaultTransport | 06Nov2023 11:25:13 | Segment did not fit in segment window: segment=2, first=3, windowSize=1, key=Key(address=Address [networkNumber=13, macAddress=[1]], linkService=[c0,a8,1,e9,ba,c0], invokeId=50, fromServer=true) |
| DefaultTransport | 06Nov2023 11:25:12 | Segment did not fit in segment window: segment=2, first=3, windowSize=1, key=Key(address=Address [networkNumber=13, macAddress=[1]], linkService=[c0,a8,1,e9,ba,c0], invokeId=54, fromServer=true) |
| DefaultTransport | 06Nov2023 11:25:11 | Segment did not fit in segment window: segment=2, first=3, windowSize=1, key=Key(address=Address [networkNumber=13, macAddress=[1]], linkService=[c0,a8,1,e9,ba,c0], invokeId=50, fromServer=true) |
| DefaultTransport | 06Nov2023 11:25:09 | Segment did not fit in segment window: segment=2, first=3, wi |
Here's my configuration and efforts I have done to debug the issue:
Local device:
OPC Device:
PING Check:
Other software(Bacnetscan) to validate the communication:
Another software Yabe to test the communication:
**Can anyone suggest what else I should do to address the issue. **
Thanks in advance.
