In Ignition Designer when I try to poll a "positive-integer-value" point I get error Bad_NodeIdUnknown. For example OPC Item Path ns=1;s=[{DeviceName}]PositiveIntegerValue371.Present_Value
Is it as simple as Ignition Designer or Ignition Edge IIoT just doesn't support that data type? Or is there a way to make it work? I did some googling and came up empty handed. Claude says:
The “primitive value” objects added in BACnet 135-2008 are newer. That group includes IntegerValue (45), LargeAnalogValue (46), PositiveIntegerValue (48) and CharacterStringValue (40). Ignition hasn’t supported them consistently: they often don’t appear when you browse a device, even when the controller lists them in its Object_List. Edge IIoT uses the same driver as full Ignition, so it behaves the same way.
I don't know if Claude's right or where I might find official documentation on that topic...
